dolsen
Louisville, KY, USA
It's disgusting that this has to be considered. I can't stand the liberals that allow this behavior. SF and LA are beautiful places that have since been ruined.
Seth Rogan went off about this a year or two ago. Someone complained about LA being a shit hole due to their car being broken into, and Seth came in saying something stupid about how that person should just leave your car unlocked, it's not a big deal. Just don't leave anything valuable in it.
Sacramento, CA
yeah im in Sacramento so we are getting smashed by the storm as well.
does it wobble enough to allow it to be pryed out?
DocBach
Nurse
Central Point, OR
2021 F150 Lariat 5.0, 2021 Explorer ST
Does it almost reach the bottom, if so a litttle padding below will help with the wobble. Same if you put shims on one side of the vault. Foam tape or such.
yeah, when I get home the foam tape is probably what I’ll do
V3nom3nom
Nurse
Picked up from dealership. Had a few things sorted out including busted driver cv boot (axle replaced), rear view camera update( blue screen), leaking cat (LH cat replaced), and few window switches replaced due to peeling chrome. Glad to be back in the ST
Safety Harbor, FL, USA
Taking mine in for a leaking CV boot. So they replaced the entire axle?
Southern California
According to paperwork, front driver axle was replaced and boot
They did the same thing for me. I believe each side is basically one OEM assembly. Simpler I suppose...
Dennis.
Sent from my SM-S908U using Tapatalk
didn’t leave anything open due to a massive rain storm there…. Luckily nobody broke my hatch
still kind of mad that the console vault wobbles after install. Not sure exactly how to remedy it to keep it from moving.
Just installed mine a few days ago - rock solid. Oriented correctly? Turned the screws all the way in? I had mine in place for 2 weeks without the screws - no wobble. Didn't want to do full install until my rear climate controls were installed.
N. Florida
People in SF are actually leaving their rear hatchs open when parking on the street near downtown. this way allows for people to not lose a window so someone can break it out to see whats in the hatch. they are more hitting for the rear seats and trunks and not so much for center consoles.
Boggles my mind that people put up with that BS. Are there no real taxpayers in CA anymore?
Started the FenFab coolant tank. Ordered a hose to put on the vent tube and need to brush the cap still. 3A485306-9FB1-4B43-9101-0FB36D8EAD42.jpeg F07F8975-2FA5-4840-9805-888BA50C34A7.jpeg
BigAnt75
Haslet, TX, USA
Just got H&R springs installed and I have not one complaint! Shout out to Jeff and Travis at Hell Horse performance for the work they did! If your in the Houston area be sure to hit them up as they do some quality work!!
StarWhite22
New York
The other day I finally figured out forscan and got the correct cable. Originally ordered the ELM327 but it would not connect to the car. Returned that and got the one that forscan recommends and that thing works like a charm. Disabled double honk (which would literally raise my blood pressure when I would forget and my kids would be sleeping in the back or my wife would jump out to run in the house for something and she had the keys. Hated the double honk) also did Bambi mode and disabled both fake engine noises. Zero hiccups or errors and it was pretty easy. Really enjoy hearing the thermal exhaust now and not the fake engine noise.
Finally washed the damn thing…it’s been in the garage since Nov and I got caught in a storm the night I parked it. Between that and all the dust from fabbing the audio crap it was big nasty. 31499620-D4B8-4BAC-A0F3-321136541AC7.jpeg
BigAnt75
Haslet, TX, USA
Finally received and installed the Steeda Springs. Pretty happy with the amount of drop and the ride quality. Just need the sway bar to show up.
Are you using spacers? Looks great!
Illinois, USA
Finally washed the damn thing…it’s been in the garage since Nov and I got caught in a storm the night I parked it. Between that and all the dust from fabbing the audio crap it was big nasty. View attachment 15997
Still drooling over the view through those gorgeous wheels. The whole setup is sharp as hell.
Did you do the third caliper EPB or built in on the Rotora setup?
mdl3v8
Kansas City, MO, USA
Explorer ST
This is bougie AF, but I installed a frameless rear view mirror from a Lincoln. I test drove an Aviator before I bought the ST and the mirror was one of the first things I noticed.
D
Deleted member 8285
Guest
ASE certified technician flashed Ford Performance Tune today. Took it easy on the way home. All went well noticed crisper shifting immediately.
Nice touch! Do you know the Part Number?
Illinois, USA
I actually really like that. Plug and play? Nothing to tweak with auto dimming or anything out of the ordinary?
