LED Reverse Lights?
RandomPilot
Lexington, Ky
So I’m seeing many different options that y’all are using for LED reverse lights. I have FORscan, so can program the hyper flash. Have we determined which ones are the end all be all bang for the buck? Thanks
RandomPilot
RandomPilot
Lexington, Ky
RandomPilot
RandomPilot
Lexington, Ky
Jeppo
Davidson County, NC
How bad was it taking the rear housing off?
IIRC, I’ve read here that some have broken off one of the tabs by yanking in the wrong direction. In my case, I’ve had absolutely no issues. Also, if memory serves, I may have used a plastic lever to assist. I’ll find links to both removing the housings and those lever tools.
Jeppo
Davidson County, NC
Jeppo
Davidson County, NC
I bought these tools without any plan to use them. Since they arrived, I’ve used them dozens of times. Very handy when you get around to a dash cam install.
AXELECT 8PCS Trim Removal Tool Car Interior Audio Installation Pry Tool Kit Window Decor Mold Fastener Removal Tool Kit https://a.co/d/64orE2H
st8
Bel Air, MD, USA
I had one of those pieces break off on one side. That same side I couldn’t ever get the light to get seated correct again. Maybe it was like that before and I just didn’t realize it.
