RTD+ Does not recognize ECU?
Shiver
NY
2021 explorer st
TC-298B,2019+ Ford is correct,I finished it today.
If you are having problems with the vcm scanner, I can give you some solutions.
NH
(2) 2021 Explorer ST (White & Carbonized Grey)
That's definitely the one I chose as well. Did you find a source for that info, or just guess like I did?
NH
It's working fine I just didn't get the channels file with the baseline. I let Adam know but haven't heard back yet. I tested with a few other XML files and my email definitely isn't wholesale blocking that extension or anything so I'm not sure what could have happened to it.
Shiver
NY
2021 explorer st
I texted Adam,he told me.Then I get two attachments
NH
Thanks - maybe I'll text him tomorrow during normal hours, for help with the second attachment.
NH
#26
Well no progress for me, I emailed last week and texted yesterday. No response to either and still no channels file. Glad you got your issues sorted though!
Shiver
NY
2021 explorer st
#27
May have to wait a few days.
NH
I texted Adam again today and he got the channels over file to me, so I'm making progress. I went right out and loaded the baseline on the car, and the channels file into VCM Scanner but now the problem is that it doesn't show any data with the channels file loaded. If I select "load vehicle defaults" it shows data but I'll have to ask Adam for guidance tomorrow.
I noticed while driving around on the baseline tune that it shows the current gear even when it's in normal/D. I like it, hopefully he can make that part of the final tune too.
Columbus, OH, USA
#29
I think you have to go into vehicle config and type your vehicle strategy # and save it for the data to come up on the channels. I've only used it thru laptop once but I feel like that exact same thing happened to me until I typed the strategy in.
Shiver
NY
2021 explorer st
#30
Select vehicle profile editor, then enter User Vin and User OS. Confirm these two information, if not working, try this UserOS "NB5A-14C204-HB" or"MB5A-14C204-CFB".Hope it helps you.
NH
#31
Thanks ridered74 and Shiver, seems like there's quite a bit of required knowledge that's not covered in the instructions lol.
At this point since I can load the baseline with RTD Flasher, couldn't I just do the data logging step with the TDN app? I tested that last night and it does appear to connect and read data successfully.
NH
#32
No luck with the laptop but the phone app seemed to work for logging. I logged a pull at lunch, uploaded and submitted a tdn request so hopefully I'm good to go. Thanks for all the suggestions for so far, I'd still be stuck at step 1 without your help.
Columbus, OH, USA
#33
Ya I send all logs using the phone and app. Just remember to fill out a tuning request thru the website after you send it so that you are offically in line for him to look at it.
One other thing to watch out for, if you don't use it for a few weeks or months and then get a revision or something and then the app says it won't connect to the device, do a firmware update. It won't tell you that you need a firmware update, but when new firmware is out it will stop connecting until you update it. One of those things I guess you just have to know or figure out on your own, but pretty annoying when you just want to flash a tune and drive somewhere real quick and instead you sit there for 10 minutes trying to figure out why it won't connect and then another 10 minutes to upgrade firmware just to flash a tune.
