Right side rattle at highway speeds
Nine29
Motown, MI
Had the same issue with my 2021 ST. I used hot glue to secure the underbody panels to the studs. Worked well so far...
BigAnt75
Haslet, TX, USA
This may sound dumb but can I see what you did as I’m planning to do that to mine this weekend and that sounds a lot easier to do.
Jp1525
Iowa
Had the same issue on the right side….rattle/clicking at highway speeds and worse driving into the wind. Had to different Ford dealers look at it with no results. Thank goodness for this forum! Thanks to the responses I found that the felt cover on the under body of the car has a loose connection right under the driver’s side post between the driver’s door and the passenger door. Remove the cheap plastic connector and replaced with (I believe) a 7mm coarse threaded nut and a large washer. There is no noise now! We were very close to trading it in for another vehicle.
M6 nut and fender washer (stainless). I'd replace them all, even if they seem intact because they'll all lose their grip eventually
BDP'sST
Virginia
yeah good news, so it looks like they fixed it. So it would seem it was one or more of the underbody panels needed to be tightened or fasteners replaced, 'adjusted'. I didn't get too much detail but it appears resolved.
The remaining item I have is the rear door sunshades are still rattling around, they have an open request or something with Ford about it, but I didn't want it to sit at the dealer while / if there is a fix provided.
What dealer in No. VA did you go to? I am taking my 2021 in for the same issue but at Jerry’s Leesburg Ford. Hoping they’ve run into this sort of thing before.
cmauro9
New Baltimore, MI, USA
#27
I just crawled under mine, and they are both loose and the left side more so than the right. I know they serve a purpose, but has anybody just removed those panels? Overtime they’re going to wear out because they’re essentially carpet.
BDP'sST
Virginia
I’m not totally sure what these panels are really for. Sound deadening? Anyway, the dealer finally traced the source of the rattle to the fasteners on this panel. They replaced the entire piece and fasteners under warranty. So, far so good and no rattles.
Jacksonville, FL, USA
Same happened to me. It’s the under panel which is slightly loose.
BDP'sST
Virginia
Yep, the Ford tech who did the warranty work was pretty adamant that the fasteners that hold the panel in are the real culprit as opposed to the panel itself.
Jackiec
Alberton MT
Ford Explorer 2023 ST
#31
Has anyone else experienced a right side rattle at highway speeds? I can be on a very smooth road and still hear it. I thought it might be related to wind noise since it doesn't occur at lower speeds, even on a rough road. Tried folding in the mirrors to see if that made any difference in the wind direction but still heard it.
Thanks.
Did you ever figure out what this was…. I had a 2021explorer and it rattled on both sides… they couldn’t find the rattle… traded it in… now my 2023 right side is doing it..
Ormsby11
Milwaukee
Do you know how many nuts it takes? I just looked at my car and looks like there are several. Did you have to pull the felt completely off to get all the plastic clips off? Also, did you replace the circle plastic clips as well?
Central Cal
Try just tightening up all the nuts. On mine that fixed it. A couple were really loose, most just needed to be snugged.
There are 6-8 of the plastic nuts all together. A bit hard to remove but can be done with a combination of pry tool and unscrewing. No need to remove the whole panel.
FYI, there is another thread about this somewhere around here.
BMW X5, Black 2020 ST
#34
I have this also seems to be from window or seat belt cover. Will also need to check the underbody
#35
Mine just started recently on the passenger side over bumps and high speeds over 45 MPH, it is high pitched like a squeaking or whistling. The left side has more of a rattle which is probaably the underbody cover.
#36
Mine is more of a light tapping sound. It's not squeaking or whistling
Luckst2046
Firefighter
2022, Ford, Explorer, ST
#37
I fixed my rattle by tightening and replacing some nuts on the right side undercarriage cover.
#38
Recently got the bottom loose undercarriage covers all buttoned up. Happy to report no more annoying rattling/tick on passenger side!
Cyclone03
Have to lol,we returned from a 2200 mile road trip in our new 2023,3450 miles now, trouble free.
Today had to go to Colorado Springs, 100 mile round trip, on the way home a wind aided flutter type rattle started. Got home and found the right side…areo felt whatever panel was loose.
Two rear nuts hanging by the last thread. I tightened those two and checked all of them on both sides, the right side nuts were all loose, left tight.
BTW those panels have to be for aerodynamics,the right one covers nothing but a big hole,the left one has the gas tank in it.
Speaking of aero,the front lower control arms are designed to move air to the brakes.
