Bora Wheel Spacers 1.5"
Toronto, ON, Canada
Hey all,
Maybe it's already been posted but does anyone have photos of 1.5" rear Bora spacers on their ST?
Tks.
F
Toronto, ON, Canada
Well looks like nobody put 1.5" on the rear..Well ...this guys did :)
Put them on today and they give the rear a more beefy aggressive look.
Just enough poke out for my liking.
If anyone wants a photo I can send, tks.
Gig Harbor, WA, USA
I'd love to see it. I have 1 in spacers on mine
JohnE
Vancouver, WA, USA
Maybe both of you guys can post pictures of the rear. I’d do the same to the front as to the rear if I did that. I have this fear of spacers messing with the suspension geometry so I’ve been holding off.
F
Toronto, ON, Canada
Ok I'll take some pics tomorrow just need to remind myself lol.
One thing I noticed is the rear tires now angle out a bit as if there was a camber kit or something. They're not straight and probably on a 5 to 10% angle..is this normal?
Iowa
I mistyped....1.25in spacers front
and back.
Do you have 21” or 20” wheels? I’ve got stock 20” wheels and have wondered if 1.25” spacers would work on mine? I do not want to cut the studs.
My bora spacers should be here tomorrow, and I have the 20's on my ST. I ordered 1.25's front and 1.5's rear. I'll let you know how they work out on the 20's
F
Toronto, ON, Canada
It does look like the camber is off. Is it the same way on the driver's side too? That would have nothing to do with the spacers.
Yes both sides are identical.
Should I get this looked at?
What do you guys think?
F
Toronto, ON, Canada
A couple of photos for yall.
Tks. View attachment 10875
The 1.5" spacers on 21" stock rims/tires.
Should the tires be on this angle?
Is this dangerous?
Been driving with them on for a few days and no issues.
JohnE
Vancouver, WA, USA
Is this dangerous?
Not dangerous but negative camber will wear out the inside of your tires faster. Handling through corners might actually be better though. For sure have the alignment checked.
F
Toronto, ON, Canada
What would you recommend? 1" spacers? Would 1" spacers cause any alignment issues?
zdubyadubya
The spacers are having ZERO effect on the negative camber people are seeing in that pic. They are just pushing the wheel further outboard so its a little more visible as you have the fender to sight along and give a point of reference. An alignment shop will let you know if you are within spec though--it could just be an optical illusion. You don't appear to have lowering springs so its odd that you would have excess negative camber from the factory.
F
Toronto, ON, Canada
Thread Starter #17
No lowering springs still stock. I might just take them off to avoid any problems.
Iowa
Appreciate it, thank you.
Toe wears tires much faster than camber. You can have 3-4° and not wear a tire with proper toe settings. I can wear the tread off a set of tires in 100 miles with nothing more than a toe change.
JohnE
Vancouver, WA, USA
What are your thoughts on spacers and their effect on suspension geometry? I’m thinking of 1.25-1.5”. If I were thinking of changing out the wheels, I know that going with a different offset would be better than spacers.
