Can anyone tell me what this noise is? Has anyone else with a new ST heard it?
Ketchup34
Crazy loud noise on cold start up.
K
Ketchup34
Could be. I didn’t think it would that loud. It’s 2021
That's not right. I'd take it in for a checkup. We could guess 100 different causes but in the end it's not supposed to make that sound.
Arden Hills, MN, USA
I get a rattle on my 21 at cold startup but nothing like that. I will be replacing the exhaust in the near future so not too worried about the noise.
FORZDA3
Gloucester, VA, USA
@Ketchup34
Sorry to say, but that is the classic Ford Ecoboost VCT position actuator rattle. Ford calls them "Cam Phasers". The problem is that the lock pin that should engage at shutdown to hold the phaser in the stopped position "doesn't" such that when you start it up, it rattles until the oil pressure builds up to hold it in position. It really isn't a "terminal" failure, but it is a big nuisance. You can mitigate it by holding the gas to the floor and crank it over several times to build oil pressure before starting. This will prevent the loud rattle at start-up, but the failed phaser won't fix itself. There is an entire thread on the topic on the Raptor forum and the F150 forum. Same problem among the various displacement V6 Ecoboost mills.
K
Ketchup34
Thanks to all for opinions and help
Waupun, WI, USA
Mine started doing the EXACT same thing.. Only on cold startup, and only for the 3-4 seconds.. I thought it might be flex pipes, but I just got under it.. I was hoping it wasn't oil pressure related... Mines also a 2021, with just around 10k miles.. Oil changed regulary.. First at 3k, then 8k..
K
Ketchup34
It’s the phasers, they replaced some other parts on mine too. It only had 300 miles. A guy on thread above nailed it
I’m not a mechanic but I think the phasers hold the lifters in place until the oil pressure builds up
Cam phasers use oil pressure to advance and retard the camshaft timing.
San Jose
Yup it's the cam phasers. I just did this to my new to me 2020
Waupun, WI, USA
How long did they have your vehicle to do the phasers?
Super G
SoCal
@Ketchup34
Is everyone here doing this method/procedure to mitigate the “cam phasers” issue? If so, anyone worried about their engine starter’s life being cut short? Or just doing oil changes every 5K miles should be fine?
FORZDA3
Gloucester, VA, USA
The starter is spec'd to run constant stop/start activity, so I wouldn't worry about that. As for the phasers, they need to be replaced if they're making the associated fail noise. The short-term workaround would be the pedal to the floor before starting, not the "fix". That said, there are several on the truck forums that have decided to just stay with it until something hard fails...
Super G
SoCal
Thanks for the heads up.
