What was the brace designed to fit?
Taz
Somerset, NJ, USA
Back to the reason for this thread. I threw on the gloss black PPF b-pillar covers from The OCD Plug to hide the scratches they all get. Super easy install and invisible once installed. Give them a look if you’re tired of the scratches and don’t want the expense of ceramic coating.
That looks awesome. Does the door code still work with the overlay on?
Thread Starter #605
There’s actually a little cut out in that area. Works perfectly....although I’ve never used mine and don’t even know the code. lol
Thread Starter #606
I didn’t even know these existed until I was on UPR’s site grabbing a fitting I need. I’ve always hated the EXPLORER indentions in the doors and didn’t wanna put the vinyl overlays in there...I wanted something to fill them up flush and damn if they don’t have them. I ordered black to match the door trim. 07515720-DE5F-42B3-AC59-61024B222AF1.jpeg CC70CABA-E082-4A30-9F4C-1A428FFAA6A0.jpeg
Thread Starter #607
Since the only CAI out there and I presume the coming K&N use the real estate UPR uses for their catch can I did a little relocation today. Had to move the ground wire, shorten 2 hoses and bend the mount a hair but otherwise no big deal. Now to look closer at the FenFab intake. 69B5556E-5E31-4852-8C90-D1B67CB6033F.jpeg A30DDD00-97CB-41A1-A517-32737062AC05.jpeg
Nbk4t5e
San Antonio, TX, USA
Since the only CAI out there and I presume the coming K&N use the real estate UPR uses for their catch can I did a little relocation today. Had to move the ground wire, shorten 2 hoses and bend the mount a hair but otherwise no big deal. Now to look closer at the FenFab intake. View attachment 5889 View attachment 5890
About to do the same but you plan on drilling into the intake for that hose (for FENFABrication) or cap it at the catch can and call it a day?
Thread Starter #609
I’ll probably weld in my own bung somewhere. I’d get the intake in raw aluminum.
Nbk4t5e
Gotcha
I’m on the 2nd round of intakes and was gonna which to the JLT one but I’ll make this work.
Thread Starter #611
Gotcha
I read that wrong...you had me thinking JLT had a CAI coming out for a second. lol
Nbk4t5e
No no lol... that FENFABrication intake is extremely nice!
Thread Starter #613
It definitely is. I drug my feet on whether or not I even wanted to bother with one but I think I will. Gonna try to spruce things up under the hood I suppose.
Nbk4t5e
What mm bolt size did you use for the relocation on the can?
Thread Starter #615
I’m not even sure. I just compared the one holding the ground wire on to the pile in my bolt bin until I found a match.
Nbk4t5e
What ground wire are you referring to?
Thread Starter #617
Mine had a factory ground wire in the hole I used to remount the can. I just moved it to one of the other holes that are already in the strut tower...it’s a self threading bolt.
Nbk4t5e
Gotcha
I checked I don’t see it on mine .
Thread Starter #619
I took a chance on some Chinese parts again. They’re stamped stainless steel and actually fit perfectly. They match the brushed finish already on the doors almost perfectly also. I did add some more 3M tape just to make sure they stay put but overall...I give them an A+ on fit and finish. 5746D3AB-7590-4609-AE46-B864D2188559.jpeg BF9CB98B-F9AF-4ED8-8F18-6D4C3672FAB6.jpeg 5E5F06A9-6763-4D29-AF89-873A2D484BA3.jpeg 6F15CEA3-F70C-4DD2-ACE5-981F885A9631.jpeg 461CC6E8-55F1-4EBB-B4DD-E55CC69A3450.jpeg
I have to say, I'm not one to buy "dress up" parts for my car, but those look fantastic and clean up what I think it the worst part of the door panels. I'm buying a set! Where did you get them?
