2026 Explorer ST ZFG E85 tune with Nostrum Stage X fuel system nets 600 Plus AWHP
Marinette, WI, USA
Ryan’s 2026 Explorer ST is officially dialed in and making serious power on E85!
611 AWHP and 590 FT-LBS to be exact!
Earlier this week, @Ryan Chiodo dropped his ST off at Nostrum High Performance for a full Stage X fuel system install so we could take full advantage of E85. We took over for the custom calibration, and the jump in power is incredible.
Here is the hardware setup:
Nostrum Stage X Fuel System & Ethanol Sensor
CVF Downpipes
3" Thermal Exhaust
CVF Hot & Cold Charge Air Pipes
CT Fab Intake
Whipple Intercooler
The Dyno Results
Here is our 93: performance tune vs the 93 Race tune 93 performance vs race.png
And here is e85 tow vs Daily Driver Vs Performance Vs Race! E85 RACE v Performance vs daily vs tow.png
Combatvet
Anyone have a rundown on everything I'll need to buy for the E85 tune. I already have a 93 tune, so I'd just have to buy the E85 version, but what other parts do I need?
ZFGracing
Marinette, WI, USA
If you're going to keep your stock turbos then you'll just need a nostrum stage 2 fuel system, if you want to upgrade turbos down the road then I recommend going with this phone which is the stagex with the Goliath high pressure fuel pump and stage 3 injectors.
Sent from my SM-S948U1 using Tapatalk
20 Platinum
Stock turbo's? Some very strong numbers. Might be wrong but I dont recall any pre 25 ST's making above 580whp on stock turbos
ZFGracing
Marinette, WI, USA
yes they are stock turbos and yes I'm not sure. I could have swore there a 591 on stock turbos but I couldn't find it.
20 Platinum
Even then, still making over 600whp is impressive. I would've thought having tad smaller turbo's creating more heat would've crippled the top end. Electronic wastegate FTW
ZFGracing
Marinette, WI, USA
They do if you try to get any more out if then!
