TEXAS Oil question
houston tx
2026 FORD EXPLORER ST
So at this point I am now looking at around 1200 miles on the clock. I think I am going to take what was said in a previous post about oil and go ahead with a oil change this week. What I am curious about is should I be running a heavier weight oil in our climate due to heat and such. I think they said to run it at 20 weight
Run what it calls for and change it when it calls for. Zero need for a 1000 mile oil change. It’s not the 70’s.
Mobile, Alabama
2025 Explorer ST 4WD
I changed mine at 1500, did a UOA, and saw no reason to change it that early. So run it. I personally change an ecoboost at 5k miles, not the 8-10k they will tell you. I am running Valvoline Full Syn 5W-30, and it appears to be shearing down to 20W, so I may be swapping oils soon or running a slightly heavier Valvoline. The closer the cold and hot viscosities the better the oil may hold up, so I will either go 10w-30 Val or swap to Mobil 5w-30.
Mine being tuned could also be a contributor to that, I dont know. All I know is what the lab shows me.
A highly debated subject but I drop at 1k, then do 5k intervals. Pick your favorite Syn 5W-30 and send it. If tuned and especially with E I like to level up to a 40wt for an insurance policy.
Mobile, Alabama
Yeah, the more I look at the 100C viscosities on the 30Ws, the more I may be going to a 40W myself.
COBRA90GT
Metro Detroit
I always get rid of the factory oil early & then proceed w/ regular oil change intervals at X number of miles ( insert your favorite oil brand/weight here ). :giggle:
Euro 30w are decent. I just skip and go to 40 on everything I have owned with FI.
