2025 Explorer ST - Basic mods on 93oct + Goosetuned....How much power does it make?!
New Mexico
Tuned a 2025 ST on the dyno today! I tune at least 5-7 of the new trucks a week, mostly road tuning. This one was on the dyno!
Super basic mod list:
93e10
Fenfab Intake
CVF Intercooler + piping
Thermal Catback
Stock these make 330-340whp. I will work on getting the stock baseline asap
456whp 525wtq
+107whp +124wtq out of an intercooler/intake on pump, not bad!
I capped torque there because I don't want to make more without catted downpipes. Once this car gets downpipes we can add another 20 to 25hp!
If you guys need custom Tuning, I'm always available and open to chat about different options! I do this all day every day, full-time! If you have any questions please ask!
EDWYER
Nice.
Derry, NH
What tuning device is needed? I just picked up a 2026 ST and have an SCT X4 from my last 2022 ST. It won’t work on the new car according to SCT. Would I be able to use it with your tune though?
GooseTuned
New Mexico
I use HPTuners. SCT wont work, that's correct.
BuckStrickland
West Virginia
What do you mean by you capped the torque there because you want it to have downpipes? I'm not as adept at the tuning process on these as I have been with vehicles I owned in the past so that's confusing. If it COULD have more power as it sits, why do the downpipes help?
GooseTuned
New Mexico
I don't like to run as much boost through the stock downpipes (this will create torque) because with more boost comes more heat, and you can reach the knock threshold much quicker.
It can always make more power, the idea here is to stay within the safe limits. This is where I mention safe and reliable, because this is very often overlooked. Once heat sets in, then it'll start to detonate and pull power. Detonation is no good for the motor.
This type of tuning is also why you don't see people post broken GooseTuned cars.
Downpipes lower backpressure, which lowers detonation/heat, which makes more safe power.
BuckStrickland
West Virginia
I wasn't sure what exactly you were saying initially. You said you, "Capped the torque", and I guess the way I've understood the process, I would've expected you to say you set the boost limit to there. Potato-Potato, I get it now. Thanks for clearing it up.
GooseTuned
New Mexico
Ahhh, I see what you're asking.
These cars are torque based, they don't care much about boost pressure (with in limits). They target a torque value, and use boost and other methods to hit that value.
For example the stock tune can run 16-17psi at sea level to make 430lb-ft of torque. Where at 5,000ft elevation it may take 20-21psi to hit 430lb-ft. The target is 430lb-ft, not xx.xx PSI. Boost will be hard limited though to stay within spec.
New Albany, In.
2025, Explorer ST
Looking at the dyno graph, so anything after 5200rpm, the power/tq is less then stock after the tune?
This isn't a flame or anything, just wondering
You’re reading the graph wrong. HP and TQ always cross at 5252. Red lines are stock. Blue are tuned.
GooseTuned
New Mexico
There is +100hp more on the Blue line (my tune) over stock at 5200rpm
GooseTuned
New Mexico
No you're good man! No question is a bad question!
ARC
Oak Lawn, IL, USA
2022 ST Black
So you don't do E50 tunes?
These cars are doing really well on that fuel blend.
I'm here in Illinois, so e85 is everywhere.
The difference in my Gearhead tune from 93 to e50 is very noticeable.
I would guess anywhere from 25-35 HP.
