Wheels and tires
ChuckD23
South GA
2023 Ford Explorer
Didn't want 22s, found these 2013 GT500 knock offs on AM. 20x8.5, 30mm offset, with 275/50r20 Atturo AZ850. They seem pretty sticky so far.
Looks good, I might be concerned about load ratings though.
C
ChuckD23
South GA
2023 Ford Explorer
Load range XL for SUVs or LTs
For the tires? I was referring to the wheels themselves.
C
ChuckD23
South GA
2023 Ford Explorer
Explorer is only 500 lbs heavier
Actually about 1200 lb loaded heavier.
C
ChuckD23
South GA
2023 Ford Explorer
I'm not AWD, and well optioned
C
ChuckD23
South GA
2023 Ford Explorer
That's with me in it, I'm 220, so 4410. The GT500 is 3850-3969. That's where I got my numbers from.
Oh yeah, well the GT500 does weigh a bit more than a regular Mustang. The new S650s are getting pretty porky too.
C
ChuckD23
South GA
2023 Ford Explorer
I was looking at a thread on brakes and needing a spacer if you have stock 21s. Is that because of the offset being 37.5mm and if you have a 30mm offset, you won't need a spacer?
Wheel width, offset and spoke profile all play a part in brake clearance. Your question as asked isn’t answerable.
sunshdw
Middle TN
2025 Explorer ST AWD
That's a great look!
C
ChuckD23
South GA
2023 Ford Explorer
Look at the first post in the thread, I think it is
It’s not. Those are GT500 replicas but they usually wont wont fit GT500 or GT350 brakes because of spoke clearance. They make templates for you to measure for the GT350 brakes and see what you may need or not need.
