Help! I need help identifying this part
Jexplorer
Mobile
2022 ford explorer st
I took my 2022 Explorer ST in because I have been having issues with squealing brakes but they didn't find anything. I looked when I got home and saw this with caked on residue. Not sure what to tell the dealer
That is the rear shock. Dust cover in particular...
J
Jexplorer
Mobile
Thank you! Is this residue normal?
J
Jexplorer
Mobile
It's weird because the other side looks perfect. No dirt. Also the ride is really rough. And noise comes from the rear side when braking
If its not wet, its not shock oil. Shock may be blown internally. Bounce both rear corners to see if there is any difference. I would also wash both shock boots and see if anything shows after driving.
The shocks are definetly blown. You can tell by the way the dirt accumulates specifically where it’s be leaking.
J
Jexplorer
Mobile
Thanks, do you think it would be covered under the extended warranty?
No cause it’s considered a consumable item.
Massachusetts
2023 ST
Rockauto has the rear ST-specific motorcraft shocks for $112 each.
They are actually pretty easy to DIY if oyu can safely remove the rear wheels
