What viscosity of engine oil are you using?
  • 0W-20
    Votes: 0 0.0%
  • 0W-30
    Votes: 0 0.0%
  • 5W-30
    Votes: 20 90.9%
  • 0W-40
    Votes: 1 4.5%
  • 5W-40
    Votes: 1 4.5%
  • Total voters
Select above.
EDWYER
5W-30 full synthetic.
Ditto. Stick to good brand names and you are GTG. I usually run Mobil 1 but I have no issue using others.
5W30 full synthetic. Literally zero reason to run anything different.
21 ST
5W30 Mobil 1
Mobile, Alabama
2025 Explorer ST 4WD
5W30 Full syn every 5k miles.
SugarMouth
Looks like most are 5W-30.
I prefer a higher HTHS. With the EcoBoost being prone to fuel dilution (viscosity falling out), plus a tune that increases cylinder pressures, my engine will stay on 0W-40 or 5W-40. I like the extra "insurance".
None of the tuners recommend doing so, so I’ll stick to what Ford recommended and tuners found no need to change.
texas
Mobil 1 FS 5w-30 (euro spec)
SugarMouth
Excellent choice as HTHS will be at least 3.5 being a A3/B4 spec.
texas
I switched to that one due to my oil test results on other oils. I will be sticking with it for the foreseeable future.
Mobile, Alabama
I went 40 on my Coyotes, but I beat those cars. Going to have Speed Diagnostics perform a couple of samples on the Explorer before I do anything else. It's a daily driver.
Colorado
Mobile 1 ESP 5w30 with a 3.5 HTHS has given me the best results. The ESP 0w30 apparently has better base oils and some esters but I have not tried it yet.
The Motorcraft 5w30 syn broke down under a 5w20 in less than 5k miles.
