2025 Towing Capacity
Caster
Also.. imo
Many people guess at what they are towing, vice actually weighing the set up
Maybe ford took that into account ???
I am sure bean counters were involved to a great degree as well
That makes no sense to me. If people are guessing, what does lowering the capacity 600 pounds change - Absolutely nothing since people are guessing anyway. On the other point: Warranty claims = Yes, beancounters were involved.
Just gleaning info from the engineer
Personally.. big difference in 5k low profile item being towed, than a 5k brick shape rv or box trailer. Using a short vehicle.
Avoiding duplication in ratings that other vehicles are rated to tow was clear from the interviewed engineer
People can tow whatever they want
The 3.0 drive train is not the weak spot,
sfenech
Oklahoma
2025 Ford Explorer
The 2025 has the 3 bolt rear?
Per Google: The 2025 Ford Explorer, including the ST, generally uses a single-bolt (or 3-bolt) rear differential mounting system, which replaced earlier designs, with the single bolt often being a higher-strength, upgraded part that addresses the notorious shearing issues of the original 2020-2022 models; the "3-bolt" terminology actually refers to the older setup that used three points to mount the diff, while the newer, stronger system consolidates to one main bolt on many models, though some reports show some 2021-2023s got 3-bolts while 2020s got 4-bolts, but 2025s standardize on the robust single-bolt upgrade.
Caster
WTH are you talking about.. You need to never ever resort to Google for info like this again.
