Got one in. Didn't realise the flex pipe is right there. We just moved it back a bit and put the Ultra Quiet right in. Stretched the opening to fit over the DP and clampped the back side. Not sure if I want to clamp the front or just weld it on. Leaning towards welding it.
Well that was an easy task! I got them both in but forgot to take a picture before taking it down. Sound is so much better! It's real quiet in the car. Sounds the same when you get into the throttle though. I did a before and after video but I don't know how to post them here. 100% worth it though!
Since putting them in Wednesday, there is a really noticeable vibration when I let off the throttle. Not immediately but, once it idles down to about 2K it starts. There’s also a rattle towards the passenger side back associated with it. Did anyone else experience this or add hangers for the new resonators?
Did you install the Ultra Quiets or the bottle style? I’m thinking the added weight between the DP’s and flex joint is causing it bounce, for lack of a better word, and vibrate. I slipped them over the DP’s and used band clamps on the back end where it butt’s up. Going back on the lift tomorrow morning to see if we can figure out a fix.
You don’t need more hangers. You need to double check your install and make sure you didnt cause something to make contact when it’s hot. You said you slipped them over the DP’s and clamped the back…you did clamp the front also, right?
I may not be the sharpest knife in the drawer but, I’m not that dull! LOL! I would think if it was making contact it would vibrate all the time but, it doesn’t. The only difference in what I did compared to what you did is the placement of the flex pipe. In your picture, the flex pipe is back more. I’m going to double check everything this morning and try to figure it out.
It must have been just barely hanging on until we shifted the exhaust. I bent the hanger a little bit so it’s not resting on the mount but, I’m gonna need a new one.
You don’t need a new one. Take them off and flip them side to side. When you added the new stuff, you shifted the whole thing back onto the hanger when it gets hot it grows and hits it even harder.
The rattle is gone but the vibration is still there. It’s not bad but noticeable. It starts right around 2,500 RPM’s or 30 Mph when decelerating, then goes away. It’s bearable but, just weird.
If you figure this out, let me know. I get the same vibration after the tech repositioned my exhaust but it happens at 1.3-1.7K RPMs. I'm stock except for DPs.
Conversely, I'll let you know if I find this problem.
If you figure this out, let me know. I get the same vibration after the tech repositioned my exhaust but it happens at 13-17K RPMs. I'm stock except for DPs.
I got the rattle squared away but even after a second look, with a third set of eyes, there is nothing we could find. I think it’s just from the weight of the resonators. It’s not enough to try to move them at this point. I can live with it.
My first impression was that by changing the lengths and flow of the exhaust, the engine dynamics were also changed, considering the stock exhaust is tuned to the engine characteristics.
That would make for different frequencies of the exhaust note in comparison to what the stock resonator was tuned for. Could also in this case create vibration due to exhaust flow disturbance/redirection.
Possible. But, I think it’s just the added weight between the DP’s and flex pipes is causing it. It only happens when decelerating and it hits about 30-32 Mph or at idle sometimes so I think it’s just the engine vibration causing them to get into a rhythm, sort of, and creating a vibration I can feel. Kind of like the vibration caused by a wheel that you can only feel at a certain speed. It gets into a rhythm and starts to shake the vehicle.
