NGK Plug change, and don't go to Ford to have it done.
Coolant
So my dealer states that they have to drain the coolant system in order to change the plugs. I've never heard of this, you merely just need to unbolt the coolant line bracket and move the lines out of the way.
Has anyone else experienced this?
Coolant lines do not need to be disconnected. Grab a tech and ask them directly if they disconnect the lines. Then you can talk to the service writer and have a fun conversation.
I respectfully disagree. Most people have never done the job and 30 minutes is not a number you want to lead people to believe.
You wanna drop by with a stopwatch? After doing it several times that’s all it takes.
Mobile, Alabama
2025 Explorer ST 4WD
Hes saying the normal person doing it the first few times aint doing it that fast.
And I clearly said “I” can do it that fast…and faster than someone could strip the whole cowl off. That was the point.
Mobile, Alabama
I get it. Just saying, some people will be in for a shock at 30 mins lol, and thats all they will read. Hell most projects I take 30 mins getting all my tools and shit where I want them.
#26
You missed my point. You have mentioned it being a 30 minute job a couple times now. This leads people to believe this. I understand after having done the job prior you could race through it but I would question that, if care is taken.
Gapping or checking gaps, re-greasing coil packs, blowing out debris in the work areas, figuring out the extension/swivel puzzle, figuring out what is in the way and getting hands fished into the tight spaces all take time.
After 130K+ miles and multiple plug swaps…I’d say plenty of care is taken. I have one of the most modified ST’s that exist…all done by my own hands. No questioning is needed.
CessnaDriver
Active Duty U.S. Air Force
Bossier City, LA 7111
I’m just saying there’s another way, didn’t say easier. If you take everything off this is what it will look like. More than one way to skin a cat. Smarter? Probably not, but you would have more room.
Did you actually removal at that stuff? The manual I had access to online said to do the same thing for changing the plugs to make it an easy access. It recommended removing the cowling, the part I stop at was the windshield wiper removal, the manual required a tool to pry the windshield wiper arm off (which I didn’t have), then to reinstall it there a programing step that has to be done.
I just ended up using a swivel stocked which worked fine to change the plugs, tight space but worked.
South Carolina
I did not remove it but seen a video where they did. When I did mine I just loosened the ac lines. The space is ridiculously small and tight (back 2).
united states
I have a 2020 ST with 97,000 miles I put cat back bolar exhaust, AFE Cold Air Intake, and roar pedal on it. I want to change plugs should I go with regular OEM from dealer.. I looking more power and life, What do you guys think about the small mods done thus far....Please Advise...
#31
Factory plugs are great for your current setup. If I was at nearly 100k as you are and doing the plugs, I would do the coils as well.
united states
What else do you recommend?
No reason to change a coil unless it fails.
#35
Yep, could wait for a failure and replace one by one sure. They could last 101k or 300k hard to say.
united states
thanks anything else you guys recommend. What about down pipes
#37
What Borla exhaust do you have? Downpipes have nice gains, but depending on the exhaust it might sound bad.
united states
I havd S Type CatBack
#39
If you have a tune or plan to tune it theyre worth it, if not I wouldn’t do it.
united states
Ok do you recommend lowering kit.. Eibach PRO-KIT Performance Springs (Set of 4 Springs) (2020-2025 Explorer ST) - E10-35-051-03-22
