Anyone else get parking lot speed Transmission clunk on their ST?
Combatvet
Every now and then my 2025 experiences a really low speed tranny clunk, only at parking lot speeds in Sport mode.
Is that normal for this vehicle? I'm about to tune this thing, and I don't need the stealership blaming the tune!
TIA
Possibly have a video? I dont think its normal.
Combatvet
Combatvet
Next time it happens I'll tap the dash cam record button.
Jon_Solo
Jacksonville, FL, USA
These STs have had a long history of having a clunk sound at low speed or when shifting from Park to Drive or Reverse. Ford replaced our read half axles and it corrected it for about a year, but its back now. Its the one thing that makes me hesitate buying a 2026 right now. I'm so tired of hearing it.
Massachusetts
2023 ST
I get a clunk/thud every once in a while when i move back/forth in gear. I *think* it's fuel in the fuel tank as it has that dull hollow sound.
It’s cause your axles need to be greased, replacing them doesn’t fix it. Greased mine and it fixed it.
Combatvet
Combatvet
It's a 2025, not a gas tank or axle thing. It's either Transmission, or something drivetrain related.
I've never experenced that with my previous 2020 nor my 2026.
Jon_Solo
You asked if this was normal, and I shared that many have experienced this over the last 7yrs since these things came out and that its related to the rear axles. I agree with 2020Raptor above it has to do with friction noise, and my dealer replaced the axles thinking that would be a permanent fix and it wasn't. Sounds like you like your own answers better.
Combatvet
Combatvet
Don't be a douche, I merely stated it was driveline related. I would be able to tell if it was the front or rear axle. But you do you!
Jon_Solo
I tried to help you with a real answer thats been documented with dealers. Didnt realize that was being a douche. You do you.
UNIT04
Nashville, TN
I definitely get that same noise, just crossed over 10k miles in my 25.
i know early 2025s had problems with their strut top mounts needing to be replaced for clunking.
