Transmission Flush
KimKinDG
Downers Grove, Illinois
Hello, new to this forum & need some advice for my 2020 ST. Almost at 70K miles, is a flush needed? Occasionally on highway when accelerating feels like hitting rev limiter and RPM's not at 5,000.
Not a fan of flush on any vehicle. In your case I would suggest a double drain and fill. Drop pan, reinstall,fill with fluid. Drive around for 15 minutes then do it again. Fresh fluid should help but if it’s slipping bad it won’t fix it.
I would never do a transmission flush. Best way to do it is to do a full pan drop and filter change. You are due for it I would say.
K
KimKinDG
Thank you!
K
KimKinDG
Thank you!
Mobile, Alabama
2025 Explorer ST 4WD
This is one of the things I do at the dealer. Did my F150 transmission, front and rear diffs, and transfer case at 50k and 100k at the dealer. Cost wasn't terrible, and it's peace of mind. Will do the same with this one.
Nunya
Do you happen to remember the cost for the services? I did front and rear dif and trans fluid and filter myself. I need the t case done. Dealership wrote a quote for all of these services it totaled to like $3k with some additional stuff kinda sticker shocked me so i did it myself.
Mobile, Alabama
Cannot remember; it was a good 2-3 years ago. They did all the fluid changes, plugs (3.5L at 100k miles), and an additional key. For some reason $1800 for everything sticks in my mind.
