Tinting gone wrong, elsewhere - need help
Pennsylvania
2023 ST
Hey folks,
I had my windows tinted a while back by a reputable local shop. They did an ok job, and I was told to come back for any bubbles that would show up after 10 days.
It showed up in my driver side window, but they also found it on the passenger side.
But then, the guy working on removing the tint from the passenger side ended up using a heat gun near the top of the door panel long enough for it to melt and get distorted. I think this part is vinyl (can anyone confirm?)
Long story short, they offered to replace the passenger door panel entirely, but I’m truly concerned that it would end up in more disasters. Mind you, they offered to do the job themselves. I know I can go through the insurance route, but I’d like to go the friendly route first, and maybe they can compensate me some other way.
So, if anyone has suggestions on how I can fix this part on my own, especially if anyone faced a similar situation before, that would be greatly appreciated.
A
Pennsylvania
2023 ST
Door panel removal/installation is not rocket science. If they get an OEM part, let them replace it.
By that logic, tinting isn't rocket science either, but look at what happened. Clearly, accidents can happen, but it's not always easy to fix them or avoid them. In this case, I'd like to avoid them while I can. For now, I'd like to focus on fixing the existing piece if possible.
A
Pennsylvania
2023 ST
You can’t fix that piece and it takes less than 10 minutes to fully swap a door panel.
Yeah, I saw a video that shows how to replace it. The problem is that they can mess up the replacement by damaging something else in the process. I'm also concerned about other things like the ST red/blue stitching (or is that standard?), that they may order the part, but it doesn't match for whatever reason.
I think you’re overthinking this. Look at the door panel before they install it and you’ll know immediately if it’s the right part or not. After that, there’s really nothing to screw up. It’s four screws, a few plugs, the door lock and the door handle pull.
Massachusetts
2023 ST
I've pulled many door panels in my day. It's actually a very easy task to do, especially on a Ford. They make these panels pretty assembly-line friendly so it's mostly 1 piece.
That area is molded, so a repair some be extremely difficult if not impossible.
The red and blue stitching is the "ST appearance package". It's not a common package and adds the red/blue stitching. Standard ST is white stitching. Standard ST-line is red. I've never actually seen this package, so does the red/blue stitching extend to the door panels as well?
I tried to find the part number for the Appearance Package panel on Tasca, but only see the standard door panel. It's pretty damn expensive. Again, this is probably not the right panel for you if your panel has the red/blue stitching on it. You'll probably have to search by your VIN or see a dealer to get the right panel if it does in fact have the red/blue stitching on it.
Looking on Ebay, I don't see any ST panels with the red/blue appearance package stitching.
A
Pennsylvania
2023 ST
This. Exactly what I'm thinking and having problems with. A replacement is likely a big issue/mismatch, hence my focus on the repair part.
Getting a replacement isn’t an issue. Any dealer can order the correct part. Again…you’re overthinking something simple.
Massachusetts
2023 ST
Agree. They messed it up. Don’t overthink it or go out of your way here.
Have a dealer get you a quote on part only or part plus repair and hand it to the shop and see if they want to pay out of pocket or go thru THEIR insurance.
Use your VIN # when the new panel is ordered. Be sure what is ordered whether you order it or someone else does, that it aligns with your vehicles VIN. You can also call a dealer and give them your VIN and have them look up the correct panel (and part number) for your vehicle. Like UNBROKEN said a couple of times, you're overthinking this.
One thing I've done a fair number of times if I'm unsure of how something comes apart that I need to replace, I wait until I have the replacement part so I can look at it to see how it attaches. A lot of Ford inside door panels hang onto the inner door panel with plastic molded in hook features along with plastic push-in clips and/or posts and only a few screws. Once all screws and clips are detached, you lift upward and then outward on the panel to remove it. The Explorer panel(s) may, or may not, attach that way but I've dealt with many Ford door panels that do attach this way.
One thing I've done a fair number of times if I'm unsure of how something comes apart that I need to replace, I wait until I have the replacement part so I can look at it to see how it attaches. A lot of Ford inside door panels hang onto the inner door panel with plastic molded in hook features along with plastic push-in clips and/or posts and only a few screws. Once all screws and clips are detached, you lift upward and outward on the panel to remove it. The Explorer panel(s) may, or may not, attach that way but I've dealt with many Ford door panels that do attach this way.
It hangs along the top and has straight clips everywhere else. To remove pull straight away from the door to release those clips then lift up. Super easy.
A
Pennsylvania
2023 ST
Thought so too, so I called the dealer, took my VIN and saw the same thing I saw on parts.ford.com: No pictures of the panel and description doesn't mention if the panel has the ST stitching/appearance package, although it did say something about "Color Accent Interior Pack" and "Race Red/Raptor Blue", so hopefully that's what it is (?!).
Anyways, I wanted to do my research and due diligence to avoid further issues and added time wasting/delays due the existing one.
I'll let you guys know how it goes, thanks all.
