Fullscreen Android Auto/CarPlay Mod Is Here for Sync3 10P Screen!! [FMods Team 10 Pees]
Chicago IL
I've been using the YEYSUA for a couple of months and it's pretty good, occasionally through Waze using Apple carplay it's a little slow to respond to touches when replying to a popup but overall I like it. I am using an iPhone 16, don't know how earlier phones will respond. The one negative about not using a cord is, occasionally using the wireless charge station under the arm rest, I sometimes forget it's not in my pocket when leaving the car.
Got it yesterday from Amazon, initially worked well in the quick test. But after two drives, ran into pretty bad lag. Another issue I encountered is I had to unplug it and plug it back in when getting into the car. It doesn’t automatically connect to my phone. Maybe there’s a timing issue (when I unlock and open door and by the time the phone is close enough to connect or the phone connects to the car first on BT before the dongle).
so far I am probably going to return it. We’ll see how it is in the drive home from work.
Orwigsburg, PA
Try removing the Ford BT connection, leaving the smartDongle connection to be the interface.
Chicago IL
Thanks, I just did it on my phone for my drive later.
Massachusetts
2023 ST
Got mine yesterday. So far, so good, but only a handful of drives.
It does show the music info on the cluster and updates as I change the songs.
SO far no complaints, but i'm only into this for $9.
Chicago IL
Unfortunately, I will be returning mine. Disabling BT to the vehicle fixed the connection issue; however, I get a lot of delay with Waze, Google Maps, and Apple Music. Delays can be anywhere from 2-3 seconds up to 10 seconds. I tried relocating the phone closer to the dongle with no change in results, rebooting my phone, leaving the cover open in case the dongle is getting too hot, etc. For $10, it was worth a shot! I have an iPhone 15 Pro.
Massachusetts
2023 ST
That's a bummer. I'm running mine with a Iphone 14 pro max and am not seeing these issues at all. Still leaving BT on. Initial hookup is pretty quick and the only delay I see is maybe a 1/4 second delay when i skip tracks vs when I use the hardwire. My music titles show up on the cluster as well.
Just to clarify however, i'm not on the full-screen mod yet. I'm about to do the install in the next few days...hence why I am in this thread.
Orwigsburg, PA
It will slow down a little bit with the full screen mod due to the extra screen area, with BT or wired, but the new layout is worth it.
New Jersey
2017 Grand Cherokee
I'm tempted. Any feedback on battery usage? My friend let me borrow an old dongle he purchased a few years ago and it worked fine. But, I noticed it went through my battery rather quickly and I was going to have to plug it in to charge it.
did you turn off the timeout for usb power with forscan or something? My 22 seems to drop all accessory power as soon as I turn the truck off
Chicago IL
Sorry for the confusion, I meant the battery on my phone.
Chicago IL
Anyone running the full screen with none of the Sync3 buttons at the bottom? Interested to see how it looks and any feedback. By default the sync3 buttons are enabled.
Massachusetts
2023 ST
How would you enable/disable those buttons? I'm running them but wasn't aware this was a selectable thing?
Also, i recall seeing a shot of someones setup where they had two, identical sized, carplay windows on top of each other. WAZE on top and a wide screen version of Spotify on the bottom. How do I do that, vs the standard 3 window display?
I did the FS mod last night. Pretty easy to do once i got the jailbreak timing right which took me 2-3 tries. Before the FS mod, my system was pretty fast, but now there's lag. Im using the YEYSUA adapter and wired. Don't really notice a difference between the two of them, but the lag in Spotify is painful, especially when scrolling through a playlist for a song. Frustratingly laggy.
I like the larger display area for sure, but the lag is killing me.
Farmers Branch, TX
There are some settings to change depending on what menu bars you want displayed in the config file. Disregard the message about a but on the last setting, this is a file from a beta version before it was patched.
ummduh
2021 Explorer Platinum
I just did this the other day and it's wonderful. The first thing I said when my wife wanted this car is "that's the most stupid infotainment system I've ever seen", but she wanted the car, so...
If I could, I'd make Ford send these guys $1k for fixing their problem.
I have a pixel 9 pro and the wife has a newer iPhone, maybe a year old. No problems with either. It did take me a few tries, I had formatted my drives in fat32 and it didn't seem to like it. Tried again in exfat and it worked the first try.
I don't care about wireless connections, no problems just plugging things in
Massachusetts
2023 ST
I actually really like this screen layout since doing the mod. It's just more usable and I actually like using WAZE in portrait mode.
It's only slow when i use the wireless carplay dongle, so really I decide on wired vs wireless based on what I think i'll be doing.
Had a coworker who had an XLT hop in my car the other day and they remarked how awesome the big screen was not knowing that's not how they originally come.
