Fullscreen Android Auto/CarPlay Mod Is Here for Sync3 10P Screen!! [FMods Team 10 Pees]
Farmers Branch, TX
20 Platinum
Anyone noticed a decrease in sound quality? Noticed it right away. Not huge, but can hear a difference, sounds a bit more muffled.
Doesn't affect radio stations
No. That's odd. Is that wired or are you using a wireless dongle?
20 Platinum
Wired.
Going by the Forums and youtube videos, others have had that issue as well
Using the latest RC1 build
US
Ford
Hey everyone I want to try this but have a few questions. For clarification 4 USB thumb drives, all FAT32 format. Stick #1 jailbreak, stick#2 daemon mod, stick #3 Fmod tools, stick #4 beta 4 or RC1 ?
Also with Forscan, will it work with a tune or do I need to flash back to stock first?
About how long did the process take? Assuming 2 or 3 tries for the jailbreak to work.
Thanks
Tune has nothing to do with this. Jailbreak is the hard part. Took me 30 minutes of trying. Some get it on the first or second try though. Also, look over the RC1 readme carefully.
Orwigsburg, PA
Thanks
You can use 4 usb sticks or overwrite the first 3 sticks but save the 4th since it has the backup files. My preference would be 4 sticks, but they should be formatted as exfat, and label them so you know which one is 1, 2, etc. They can be old sticks since the largest space taken up is less than 7 MB, so you don't need a 64GB stick.
You also don't necessarily need forscan, it can be installed by using the radio power button and forward buttons simultaneously to do the reset.
Both beta 4 and RC1 are stable, I went with RC1. The caveat with RC1 is, you need to move the files in the dist folder to the root directory for the mod to load.
Like previously said, the jailbreak is the tricky one, timing has to be right. If stick 2 gets an error trying to load, the jailbreak wasn't successful and you need to do stick 1 again. Turn off your headlights every time you turn the car back on to save battery life, or hook up a charger.
20 Platinum
Thanks
As others posted, its a hit and miss. Got mine fully done under 10 min. Make sure the Sync 3 is fully updated. RC1 is the way to go, there still some small bugs but its reliable.
Make sure when installing RC1, you move the files to the root dir. Else, it wont work. Also, wont play nice with some USB drives, I had to use two different drives to install RC1 as one didnt want to work properly with Sync for some reason.
Farmers Branch, TX
Does anyone know what changes were made between beta and RC1? I'm still running beta 4. The mod publisher did not post any info on fmods that I can find.
I believe they got the Sync button working if you opted for the full screen (without menus at the bottom). If you are not opting for that, it's the same.
US
Ford
Thanks everyone appreciate the help and advice. Will give it a shot this weekend.
Sent from my SM-T307U using Tapatalk
OgRoar
PNW
I was able to get this setup tonight. I haven't had a chance to mess with it other than to see the map is full screen and Android auto looks great. What else can we do? Any video players? Would be cool to use Plex. Also, is a full screen camera using the camera button possible?
Massachusetts
2023 ST
I've found another wireless Carplay dongle that is just as responsive as the Expinsig (unavailable). The settings page looks identical to the Expinsig and is at 192.168.18.8. Safe to say it shares the same firmware. Best of all, it's inexpensive. I bought it 2 days ago at $30, now it's $20. If you don't like it, return it but for me, nothing comes close to how responsive this is with minimal screen touch lag after doing the fullscreen mod. Much faster than wired carplay.
YEYSUA https://a.co/d/6jay5Dr
Price drop to $9 if anyone wants to try. I ordered one.
Chicago IL
I'm tempted. Any feedback on battery usage? My friend let me borrow an old dongle he purchased a few years ago and it worked fine. But, I noticed it went through my battery rather quickly and I was going to have to plug it in to charge it.
Orwigsburg, PA
I've been using the YEYSUA for a couple of months and it's pretty good, occasionally through Waze using Apple carplay it's a little slow to respond to touches when replying to a popup but overall I like it. I am using an iPhone 16, don't know how earlier phones will respond. The one negative about not using a cord is, occasionally using the wireless charge station under the arm rest, I sometimes forget it's not in my pocket when leaving the car.
Orwigsburg, PA
With my old phone, Waze would eat my battery so I would need to have it plugged in. that wasn't using Bluetooth, I was just using the phone screen for navigation. No drain on the battery with my new phone using Bluetooth.
Chicago IL
How do you bring it back to stock without a ford update?
Check the readme file or the file with the instructions; it's a similar process to when you do an update for the fullscreen mod. You just have to set some flags in one of the config files, and you have to copy your original backup files or re-use the same stick and just change the flags in the config file.
Chicago IL
Thanks, I ordered one for the heck of it. Lets hope it works out for me!
San Francisco
I completed the install in 11 minutes after loading the 4 usb drives. 3rd try for jailbreak. Using Iphone 16 pro corded. The only bug I found is bluetooth and audio source disabled once Carplay starts, not a big deal. Previously you can switch audio sources with carplay on. I also have a the forward/360 camera speed bypass hardware unit installed and that is unaffected, double honk key left inside disabled, fog lights on with DRL, and surround sound enabled soo anything forscan is also unaffected. Following this video:
