Purchased the Velgen VF9’s with Toyo Proxes STiii’s 305/40/22 and absolutely zero rubbing!
Here’s my issue. The 4wd Fault Service Required popped up on the dash and started throwing codes. I went to Ford and they said it’s because the overall diameter is larger and there is nothing they can do to reset it. I went in to Forscan and changed the tire circumference but the 4wd service won’t clear. Anyone dealt with this and has a fix?
