How-To: Creating your own ST Lighted Cup Holder Harness
eskanST
California
Taking inspiration from this post:
https://www.explorerst.org/threads/...ted-cup-holders-glove-box-light-missing.7831/
I created my own adapter harness to power the ST lighted cup holders that were removed in the later ST model years. Here's documentation of what I've done with included part numbers so you can create your own harness.
Note for the folks who don't want to DIY, you can send these instructions to a car audio shop and they can build out the harness for you.
The Core Parts:
Lighted Cup Holder: LB5Z-7813562-BA
LED lights and harness: LB5Z-14A318-K
Tools and other Materials you May Need:
  • Wire stripper
  • Scissors
  • Electric felt tape
  • Wire taps (I highly recommend PosiTaps)
  • 22 or 20 gauge wire
  • Heat gun
  • Wire connectors. Several choices available:
    • Crimp
    • Posi-Lock
    • Solder seal
I decided to tap into the Passenger Footwell light wires. These instructions should work for the Driver's side Footwell light connector as well.
There are 3 wires that power the LED light:
  1. One wire is ground
  2. Two wires are digital signals sent to the microcontroller for the LED light. I assume they control luminosity and color.
I believe ground is black and the blue and green/red are the signal wires (I didn't bother to measure the voltage and did not have the wiring diagram available to me).
The LED lights and harness for the Cup Holder have the same wiring configuration as well (black is one side, blue is in middle, red is on other side of the connector housing). The wires are actually black/grey or black/purple, blue, and red/green, but I'm going to just refer to these wires as black, blue, and red.
Here is what the Footwell connection actually looks like:
Quick and Easy Method
If you don't care for making the wiring "pretty", you can just buy one pigtail (Motorcraft Part #WPT-1182) and use wire taps to tap into the wiring for the Footwell light. You will need to get extra wire, wire connectors, and wire taps as well to make it all work.
Be sure to match the wire colors up when you're taping the wires:
  1. Black taps into Black
  2. Blue taps into Blue
  3. Red taps into Red
More Professional Method
This is what I opted to do. I got two additional pigtails to create a Y-style harness that is plug-and-play (no wire taps). In addition to #WPT-1182, I needed to get:
  1. One #WPT-911
  2. The male equivalent for #WPT-911
Due to my lack of experience working with modern American cars, I couldn't figure out the actual connector or pigtail part #, so I resorted to sleuthing around on eBay and found out that the footwell light connector for the non-ST version of the Explorer had the male connector (connector with the pins).
Here is the part number for this footwell light connector:
#LB5B-13E721-AC
Once I have all my connectors in place, I used solder seal connectors (it's a combination of solder and heat shrink tubing) with my heat gun to create the Y-connector:
I then used another set of wire connectors to connect to #WPT-1182 which connects to the Cup Wiring harness.
Watchouts
  1. When using the Motorcraft pigtails, make sure each wire corresponds to the correct wire color. You will need to test fit your pigtails and note which of these green wires corresponds to which colored wire on the other side of the corresponding connection.
  2. When testing your wiring, the car may cut power to the footwell light wire when it doesn't detect the footwell light over a period of some determined time. This happened on my car and I had to close the door, lock the car, and then open the car to get power from the footwell connection.
Cost improvement
These pigtails are not cheap! If anyone knows where to source the actual connector housings and terminals, please chime in. I believe these are USCAR style connectors, but I'm not sure since I could not find a part number on the connector housing itself unlike other connectors that you find on foreign cars such as Volkswagen.
Building the pigtails from scratch will reduce the overall material cost immensely. I manage to find good deals on these pigtails on eBay.
There are two additional ways to do this cheaply:
  1. Tap into each wire that goes into the LED Cup holder lights and connect those wires to the Footwell wires. You will need 6 taps for the cup holder side and at least 3 taps for the footwell side.
  2. Forgo the female housing connector and just push in the female terminal pins directly into the male pins, aka "flying leads". The terminal pin width is approximately .70 mm to 1.1 mm. You will need to experiment and order a few different sets of female terminal pins from Mouser Electronics or DigiKey to find which one works.
Good luck building out your own harness!
Massachusetts
2023 ST
Awesome thread and thank you for doing the legwork here. I have the cupholder and ford harness, but was delaying on install because of this adapter harness needed. Mostly I couldn't figure out the connectors as I wanted a plug-and-play harness.
You are right about the pigtails being expensive. WPT-1182 comes up as being stupidly expensive. Since ford shared connectors in many other vehicles I've often resorted to hunting Ebay for parts which use that connector, and then clipping it off. Also, junkyard may be an option for some.
BTW, Ford does have a connector catalog.
connectorcatalog.pdf
I think these are the two main plugs. Correct me if i'm wrong. I think the mating connector to WPT-911 is WPT-1103, but I cannot confirm as i don't have a good shot of that connector.
But thank you for this information, as now I have a starting point to source the right connectors and put together a harness.
eskanST
eskanST
California
Thanks for linking that connector catalog!
WPT-1103 does look similar to the pigtail I got. I hope someone out there is willing to order it and confirm. If it's confirmed, I can update my instructions in the original post.
I need to do this for my rear cupholders…I bought the harness that plugs into the rear console already and it snakes under the carpet to the driver seat where I plan to tap into that light. I’ll have to see if the connectors are the same then I should be able to just follow this tutorial.
Massachusetts
2023 ST
Do you recall how long you made your harness?
Managed to track down a cheap WPT-911 on Ebay. Looking for the others at more reasonable pricing. $90 for WPT-1182 is more than I paid for the cupholder and lighting harness combined.
eskanST
eskanST
California
I believe it was about 3 feet. I would double-check before I start joining the wires.
Alab23
Houston
Ford explorer st 2022
Would you be willing to make a video on this I’m sure it would be a big hit
Massachusetts
2023 ST
I still haven't worked on this yet myself. I have the cupholder, the LED light harness, and one of the connectors I need. Been meaning to pay a trip to the local junkyard to snip some harness connectors off some wrecked explorers. I'm not paying $90 for a simple plug from Ford. Haven't put the legwork in yet to see what other cheap Ford parts i can snag off ebay that have the same connectors that i can steal them from.
wanted00
sugar land
2022 explorer
does any one any update? I will use wire tap for both ends instead of paying 100 for connectors. Also I want to use that power for center box light. did you check voltage for that?
Massachusetts
2023 ST
I haven't done anything with it yet. I've purchased the cupholder and LED lighting, but stopped at making the harness due to the ridiculous pricing of the connectors to make a plug-and-play type harness with the original ford style connectors. I wanted to just unplug a factory connection and add in my new T-harness.
Probably going to go this route and make a t-style harness using these connectors. Will require cutting the original 3-wire harness somewhere, adding the connector on each side and making the harness. Unfortunately not a huge priority for me right now
https://a.co/d/6UR44nA
wanted00
sugar land
2022 explorer
Does any one have experience to power glovebox light with that connection? It gonna need power and ground. When i start doing it I will check the voltage but any upfront info will be perfect.
Massachusetts
2023 ST
It’s not power and ground. It’s a RGB type LED that requires 3-wires and needs to tap into the existing ambient lighting system. That’s how it’s designed so you can cycle through the various optional colors
wanted00
sugar land
2022 explorer
I think its something like +, GND, and control. So i planned to get + and GND for glove box. and extend all 3 for cup holder. So I need to find another +
Massachusetts
2023 ST
Ah you are right. Not sure why I missed that. In fact now that gives me another idea for how I can wire this up. (y)
wanted00
sugar land
2022 explorer
I will try to install at Christmas. Also I will try to share some pictures.
wanted00
sugar land
2022 explorer
I installed today and nothing works :). It was getting late so made it fast without controlling, probably wire taps are loose. I used wiretaps everywhere. I didn't want to cut sockets. But i think its gonna change. This weekend I will for check all. For glovebox I found another line from front box with the USB's. I got power from there and extend it for armrest also. Tapped a Y. One end to glovebox other to armrest. I got the 3 wires from passenger footlight to cupholders. Made 2 sockets (Glovebox and Cupholders) to right side of center console to easily remove console next time. I don't like to hack and made up parts but i already started to hack so i will put a switch to armrest. I couldn't find a switch like in the glovebox. I will 3d print an arm for the switch and install it. I didn't order yet armrest lights. I wanted to see and figure out what to do. But I already pull the wire. So no need to remove console to install that.
Massachusetts
2023 ST
Often times, with data control wiring, the ground wire needs to be sourced from the same module as the control circuit if the ground is isolated from main vehicle grounding
I have no idea if this is this case here but something to keep in mind if you continue to not be able to get it to work
wanted00
sugar land
2022 explorer
It turned out to be loose wire taps. I guess they were bad ones. I ended up cutting and soldering the wires, and now everything works.
As you can see in the picture, I printed a leg for the armrest box, but it hits the sockets on the panel. It needs to be shifted about 2 inches to the right. I’ll fix it once I get the light harness.
