2025+ Ford Explorer Spreadsheet now available!
Nightshade
Firefighter
Alberta, Canada
Below is the link to the updated FORScan changes that is currently available for our 2025+ Ford Explorer and applies to all trims for those who don't have an ST. This one is for us, which helps compile all into one.
Keep in mind that the sheet will be updated by @powerboatr and @Nightshade (myself). If you're interested in something that isn't on the sheet yet, just reach out to myself or @powerboatr or comment on this thread.
LINK: https://docs.google.com/spreadsheet...bxZh92wdcE/edit?gid=1931803578#gid=1931803578
--DISCLAIMER; for those asking me regarding the turn signals to change from 3-clicks to let's say 5-clicks, it won't be possible. I looked into this myself and the issue is that the signal stalk on the 2020+ Explorers are using a slightly older stalk so issue isn't just software, but also hardware. So in saying this, changing the turn signals in FORScan will not be possible for the 2020+ Explorers for the unforeseeable future.
RFord78
Following
Mako
Canada
Is it really not possible to have the amber light on while in park?
I’ve also seen people running only the amber light without the side marker on. On my car, the side marker always comes on with the amber. Do you know if they disable it using FORScan as well?
One last thing, when would you want to use the DRL full brightness mod?
MichaelTM
Missouri
So. I have a 25ST and I've changed the drls, the fog and high beams. And I also wanted to change the Allow cam in any motion so I went and saved the as-built did everything requested restarted the ignition and it works, but my speakers have started crackling and popping randomly at any volume, is there something I could've missed or messed up? I hard restarted my radio and I also reverted as built file and I also loaded in the factory ACM file and nothing is working and its been stressing me out. But why would changing the camera at any motion and speed affect my speakers? Any help would be amazing! I changed 7D0-02-02 xxx3 it was 2 to start with
25ST job1
Anyone find where to add the keyless entry in forscan ? I found them available, but hate to give the dealer $ when I have a forscan that ive been able to use on my last dozen vehicles.
대한민국
2023 링컨 에비에이터
Can I share a 23-year-old Aviator Threadsheet?
Nightshade
Nightshade
Firefighter
Alberta, Canada
You can only run ambers in either drive or neutral. As for ambers without side marker on, you need to disable "Allow brake lights to turn on with DRL" in BdyCM module (easy way, not asbuilt). When you disable this, it'll turn off your rear parking mode in daytime DRL mode and the front headlight side markers.
DRL full brightness only works when its dark and white LED bar is on + headlight knob set to switch 2 which doesn't turn on your low beams at night); can be used in all modes at night.
Nightshade
Nightshade
Firefighter
Alberta, Canada
Cams in motion is already enabled by default from factory and is a separate module than your speakers. Speakers are under ACM module. Any chance you disabled the fake engine noise in FORScan before?
Nightshade
Nightshade
Firefighter
Alberta, Canada
Very easy to do. Do the following after it's installed:
Step 1: Enabled "Keypad" in BdyCM which enables the hardware itself (use Keypad in search bar in BdyCM module in easy mode, not asbuilt)
Step 2: Enabled "Keypad" in APIM successfully, enables the option in your infotainment screen.
Step 3: Perform the BdyCM Local Interconnect Network New Module Calibration (will be in the wrench icon on the left bar in FORScan).
Gluestick
Nashville TN
This was great. Looks like the auto start/stop disable in this spreadsheet didn't work for my 2025. I have disabled double-honk, the camera black box is gone, and my DRLs are amber, fogs enabled with high beams, and phony engine noise disabled (need to drive around with music to validate I have no adverse affects so far).
Any chance the values for the global window open can be configured to do all four windows?
Any chance the global window close can be enabled? (On my '23 bronco, I was able to enable that and hold down lock button to close all the windows).
I reckon there are no performance dash screen or gauges available to use with Sport mode...
Marietta, GA
2025 Ford Explorer ST 4WD
Greetings:
I tried ForScan reprogramming a 2025 Exp ST today.
SUCCESS: Bambi mode enabled.
FAIL: No joy on global window close with remote.
QUESTION: FENG removal states, "If first digit is 1, change to 0, this will turn off ANC (active noise cancellation). use 2 to keep ANC enabled." What if my first digit is an "8"?
Thanks for all the work you have done.
-RFC-
MichaelTM
Missouri
No I never had the fake engine noise I just wanted to be able to see out the front cameras while I was driving but the speaker issue cleared up and I've been to nervous to change it back since my speakers popped and crackled pretty bad
25ST job1
i got the new keypad trim installed and enabled keypad in the Bdycm, there were 2 options - hardware and LIN. i tried hardware, then enabled in the APIM, and followed the calibration. I am unable to get anything more than the keypad to light up. it wont lock or unlock, in fact, it seems to time out after 3 button presses. I verified keypad options were set to 5, ran the procedure a 2nd time, same results. for the 3rd time, I tried the LIN option, followed by a calibration, followed by entering new codes. nothing. same issues, seems to time out after 3 'presses' and wont lock or unlock.
as a note - to obtain your factory code, have both keyfobs with you, place one in the slot inside the center console, ignition on, count to 10, ignition off, switch to the other keyfob, ignition on, and the code will appear. I strongly suggest writing this inside the manual suppliment and keeping in the glovebox.
Gluestick
Nashville TN
I did the keypad via FDRS in the end. BUT I DID GET GLOBAL WINDOW CLOSE TO WORK via remote using FORScan by using the “easy mode” and setting all the rear window global close settings to match the fronts. Voila!
Marietta, GA
Where did you find the rear door modules? Mine only opens the front windows (from factory) and did not close them. I can close them now but thought it odd that the rear windows did not follow.
I found easy mode once by accident... how do I find it again?
Gluestick
Nashville TN
oh, still just front windows - not rears. But I got them to close with keyfob now by holding the lock button. Nothing doing on the rear windows up or down.
The easy mode is the menu for configuration that doesn't say "AS BUILT" - where you aren't putting in codes, but using the dropdown picklists.
MichaelTM
Missouri
Was looking around in the spreadsheet and came across these,
7D0-13-03 xxxx xxx* xx-- Launch Control (LC)
7D0-09-03 xxxx xxxx *x-- Lap Timer (LT) • Brake Performance (BP) • Acceleration Timer (AT) • Driver Select Suspension (DSS)
I'm curious about these 2 changes, I have a 25 st and I dont have any of these features and I would like to have them but I dont know if it would work since I've had issues in the past with changing APIM as built files. If anyone has changed these or can test it out and see what it does or I can try it in the next upcoming days and see if anything interesting happens, i dont know.
Pbmustang8248
West Virginia
When I try to put a zero in the ANC field I get a warning of a typo. If I say yes it pops a prompt that this will rewrite entire module
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #19
Anytime you change any values in the as-built modules, will always show that warning. It's normal.
Just be sure to write only that section, not the entire module.
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #20
Launch control doesn't work for ST, it's parameters doesn't see the ST as a racing line apparently. But the Raptor has it, I know because I have a '24 F-150 Raptor too haha.
But if you'd like to try it, back up that module to your folder and write the changes so then you're able to revert the changes if anything happens.
