오일팬 변경
대한민국
2023 링컨 에비에이터
엔진오일 미션오일 팬 알미늄 으로 변경은 어떤가요?
PPE.BG.FEN 업체가있던데
PPE.BG.FEN 업체가있던데
I had to translate your text from Google, but seems like you’re asking about an PPE transmission oil pan. Unless you need the extra capacity deep pan, then it’s really not worth it.
포드링컨
대한민국
2023 링컨 에비에이터
Thank you. It's pure plastic, so I'm thinking of switching to aluminum because it's damaged
감사합니다. 순수 플라스틱이라 파손이 되어서 알루미늄으로 바꿀까 생각 중입니다.
It doesn’t break. It’s perfectly fine there.
Oh in that case why not. Can’t hurt. Should’ve specified that you needed a new one.
포드링컨
대한민국
2023 링컨 에비에이터
Do you have any companies you can recommend?
포드링컨
대한민국
2023 링컨 에비에이터
Thank you. You answered a lot of questions. Do you have any recommendations for replacing other lower body parts? The tuning parts look stronger than the original ones. Is it a waste?
Not a waste if you drive it hard. I replied to your other post.
