How the frig do you program home link garage door openers?
Ct
25 ST
Am I missing something? I’m following the directions on the owners manual on the vehicle… I can’t get anything to sync up. Is there a trick? I’ve reprogrammed new handheld openers for 2 garage doors and external keypads…. All work, but the damn ST won’t !!! I’m not an IT guy but I handle all the tech at work and home, it shouldn’t be this difficult!
Nine29
Motown, MI
Try going to Homelinkcom site and input your car and garage door opener for specific programming instructions. I had the same problem as you and followed them and it worked first try.
Missouri
I followed the instructions in owners manual and it took all of 30 seconds to work.
Here's a little trick I discovered about 6 years ago that they don't tell you in the instructions in the owners manual. TURN ON the IGNITION. You don't have to start the vehicle, but you do need the ignition on. Then follow the instructions and you be working in about 30 seconds.
Fmoser
Ct
25 ST
lol. Yup, tried ignition on, car running and any other combo.
I tried for about a week, multiple cars, 2 different doors… every one worked but mine!
So tonight I asked my son to help me one more time…. He pushed the button on the garage door motor, I did the car…. Same as it’s been done many times before….
It friggin worked on the first shot!
Northern Illinois
Go to you tube it's easy
Illinois, USA
Push program button on opener, push and hold home link button until it changes from fast blink to slow. Let go, should be done.
Fmoser
Ct
25 ST
Believe me, been there done that… I’ve helped the neighbors, the last 6 cars in our house, at work, etc…..all went smooth and no issues.
For whatever reason it wouldn’t work on my ST until that last try, the same damn thing that’s been done time and time again.
Illinois, USA
Were you able to get it? Otherwise you can reset the homelink. Hold outer two buttons till the blinks change.
Curious, will it let you program a button that has been programmed without a reset?
I always do a reset before I sell cars.
f150ST
colorado
25 explorer ST
I cant get mine to pair either
On mine, once I pair it with a garage door remote and verify it opens the garage door, I hit the LEARN button on the opener and then press and activate the Homelink button on the car once more--otherwise the next time it won't open.
California Bay Area
I currently have Chamberlain garage door opener. From my experience, I had the same issue getting ST to accept the signals from the remote if I used a generic remote (3rd party) which I purchased from Amazon. It used to work on my Ford Escape but I have no idea why ST refused to accept the signals. I had to dig into the storage to find the original remote and with the original remote, I successfully programed the Homelink in about 5 mins.
joelk9
Indiana
I had similar issues with a Genie garage door opener. Found resetting the transmitter in the vehicle and then performing both programming methods for it to work. Here is a link to then YouTube video I followed.
Orlando
Thank you my friend. I hope your bed is cool as a cucumber. Just had to do remote and motor double sync to get home link to work.
bnewt
Shepherdsville, Ky
Your son must have the magic touch:giggle:
