6 Faults and AWD Module
cliballe
Tennessee
2020 Ford Explorer Platinum
#81
Yes it should be under powertrain warranty. Find another dealer!
I've been reading several threads where you and some other members posted about your dealer covering various front axle TSBs, AWD modules, etc. under the powertrain warranty. We are hopefully getting my mom's back from the dealership soon for what we feel falls under TSB 23-2061, and she's outside of the bumper to bumper warranty as well. We are hoping Ford will cover it, but would you or any any of the others be willing to share a copy of your invoice where your dealer covered the repairs under powertrain warranty? I've been looking around and maybe you already posted it somewhere.... I found one invoice where all of the front axle TSB issues were addressed on a 2020 with like 41K and outside of bumper to bumper so that was helpful too. We're just looking to have multiple examples of where Ford is covering these repairs in case the dealership tries to charge us. Thanks in advance!
San Jose, CA
I finally got it to the dealer and they said the AWD module needs to be replaced as I thought. They said the total including diagnosis is $839.47. It's feeling like they aren't going to cover it under the powertrain warranty. I'm just not sure if I want to fight it right now or get it over with.
Table Rock, SC
2020 Explorer Platinum
#83
Here we go again. So what ya say about me going back to the dealership to fix the AWD module a second time. The service write-up tech. Was not happy the first time with my explorer. Kept finding problems after problems. I didn't tell him to fix all that. He did it on his own. When he called me for vechile pickup. I asked if it was covered. He said he wouldn't have fixed it if it wasn't. Seem to me some stuff he fixed extra. Well, the Explorer was brand new again back in August until today. Pulling into Zaxbys and threw all 6 faults back on again. So what ya say. Should I try a different dealership an see if they fix it. Because Fairway Ford definitely ain't gonna fix it. They won't even call me back about the Reverse blue camera recall. I want my Chevy Impala back
#84
I just had this done under powertrain warranty. I had the codes and grinding noise when turning backing in and out or making a u-turn and the car also drove lurchy with intermittent disconnecting and reconnecting of front axle AWD. It took about a week to complete and was provided a free rental car. I have 49,700 miles and 8 months left on Powertrain Warranty!
https://www.explorerforum.com/forums/threads/technical-service-bulletin-23-2174.505026/
George M
Painesville, OH
Anyone have this issue and it just be the battery? I'm getting same thing but only comes on with adverse temp change (NE Ohio); like 5 degrees all January but yesterday was almost 50. Goes away after restarting vehicle. Doesn't come on with every drive.
#86
You should run a scan to see what codes come up. A lot of different faults have the same dash warnings.
George M
Painesville, OH
Ya...fair enough.
George M
Painesville, OH
Does the awd module need to be programmed or is it plug and play?
Table Rock, SC
#89
It has to be programmed. Mine keep going out. Now my explorer feels like it wants to shut off. After time i ⛽️ fill it up. While it's running. Great don't know if it's the fuel pump or something else. Almost didn't turn over on my fill up this morning
#90
If the AWD module issue is intermittent and you get the codes for it, you should at least try the grounding mode listed in the TSB. Dealers don't seem to want to do it and push for a new AWD module--whether covered under warranty or not. It's probably just easier for them. I don't think it's coincidence that those with failed AWD modules happen to be Explorers that fall under the AWD grounding build dates.
Kemot
Sarasota, FL USA
2020 Fprd Explorer ST
#91
2020 ST, all warnings lights on dashboard, including AWD module, sent car for service, they replased batter + they ran diagnostic ($600), and came AWD module need to be replaced qoute for $1700, removed the car from delaer, now trying to fix my self.... any help guys
I am not sure If I will get this done in one week as I am leaving for holiday, and I need to frive 250 miles to catch a flight - is it safe?
thx
George M
Painesville, OH
A new module is like 200 bucks, where are they getting 1700 from?
I had the TSB 23-2174 and I drove the car for awhile with no issues. Currently at shop for fix under extended warranty. Anyways, I had the same symptoms and car was fine. It'll probably disconnect your awd so it'll be rwd until it's replaced. And your cruise control and certain sensors will be turned off until it's fixed. But mechanically it should be ok. No guarantees ofcourse
Canby, OR
$1500 in labor to replace a 4WD module? You just need to get to the 4wd module and it's under the carpet under the drivers seat. A lot of them just had bad grounds. I would check the connection first. If you have to replace it, it does need to be programmed to your car.
Kemot
Sarasota, FL USA
#94
THX for the disconnection idea.... i am not mechanic :)
Venice, FL Ford Service, qoute me $1700, also they said no under my extended warranty. now I am looking for my way to fix it.
George M
Painesville, OH
All. My issue with the AWD was not the module. It was the electronic actuator on the intermediate shaft; reference TSB 23-2174. I have a 3rd party extended warranty and they approved the claim, just had to pay my deductible.
Car has since been fixed; all issues gone.
Kemot
Sarasota, FL USA
#96
So.... update.... and suprise so far.....
as my Ford dealer service said and quoted: I need replased AWD module, $1700, but to do this they changed battery in my car ( I understanding as I know it can be the problem as was 4years old, paid around $600 battery + diagnostic - I thing its to much). So after some reading, (saying if you change battery and clear all faults system should come back to normal), but service said is faulty any way even I point that...so I took my car back and tried to do it my self + friend car mechanic with access to ford data for programing.... I orderd used one $120...unfortunetly when I arived his laptop died on us... yes laptop died... so we had to chenged back to my orginal one ( diagnosed as faulty), but my car mechanic wanted to see what is wrong...... he notised 12 faults and cleared them all. he ran another diagnostic to double check and noticed NO FAULTS, NO ISSUES....... so after 10 min with a working car in his garage + 15miles driving back home my car was fime, no problems no issue and its working like never happened..... but real test coming tomorrow as I will do around 600 miles..... so end of the day and story I fixed mu car for FREE (for programing he wanted around $150)... what shoud I thing now about them .... for sure i will not agree any more for any $$ repairs in this service....
George M
Painesville, OH
Clearing the codes will temporarily fix the faults but if something is actually broke the codes will come back eventually.
Kemot
Sarasota, FL USA
#98
yes, you right for sure..... but lets be honest.... that something is Ford in general :).. so I know will come back... but not for $1700... do not take me wrong I love my ST but my is 3-4 times each year in service, and mostly for transmission issue, which we all know it will never be fixed/corrected.... some times I am saking my self what happen if can be change to 6 speed transmission :)... all the best
#99
I'm having these alerts again this past week at 61.5K miles . This first happened 2 years ago and had the half-shaft speed sensor replaced. Then following year the FADA TSB was done. Next week it will go into service to find out what the issue is. The alerts went away a few times then for a couple days were consistently on. Today it's only the 4wd Fault alert so intelligent cruise, collision assist, reverse assist, auto-hold, traction control all worked today. So I'm guessing it's a 4wd sensor or transfer case again. It will be under ESP and rental car covered.
UPDATE: Got my car back today and they replaced the AWD Module, which was the first time for this part. So it drives really well now!
