PSA FOR EXHAUST RATTLE
For anyone experiencing exhaust rattle - NHTSA TSB # 10179152.
Ford service (should) take care of it OR for the DIY Guy... A 90mm 3.5" Worm Gear Clamp tightened to 2.7 NM on each Flex Pipe.
(After Market Exhaust & SPD Downpipes exacerbate the rattle and make it completely unbearable)
** Footnote for all Borla Exhaust owners (and potential owners) there are 2 points of contact above each muffler; a bolt and screw that can be baffled by measuring and then (drilling and mitering to cover) an inexpensive exhaust bushing and using a silicone adhesive to mount over the screw and bolt.
(Example)
https://shop.namelessperformance.com/exhaust-hanger-bushings/?sku=NPBU
*Or another fix is to dent the top of the muffler with a hammer so it doesn't hit/rub against the bolts... but whatever you're comfortable with.
Sent from my SM-N986U using Tapatalk
(Example)
Are all of your rattles gone now with the SPD downpipes and Borla?
