ZFG 91 on E30 Vs E50?
Illinois
Volvo XC 60
Hello, I finally tuned my ST - Currently running ZFG 91 on 93 and fairly impressed. I haven't got the chance to put in a E30 mix yet to see if there is a seat of the pants gain. I went with 91 tune because 91 is a little easier to find than 93 and the stations closet to home are ONLY 87. Im trying to run 93 only. A station that isn't super inconvenient does have E85. I would assume the difference/gains between a 93 tune running 93 or E30 would be very minimal compared to a 91 tune running 93 or E30?
If I could do this over again I think I would have gone with goose tuned. Not that I'm not happy with ZFG but based upon what I have read here and on Facebook people are just as happy with Goose - and I could switch tunes much quicker. It's my wife's car and I'm not going to ask her to switch tunes when it takes a good 10 min. With goose my understanding is it doesn't take near as long and I could just tell m my wife to plug in the device, click a few buttons wait 1 min, then fuel up.
My question is: how much of a difference is there between my tune on E30 and a straight E50 tune? Dyno numbers don't tell me too much although interesting - I just want a seat of the pants change. I wouldn't get to play on E50 very often as its just too inconvenient but I guess the occasional fun might be worth it? CVFAB intercooler and FenFab V2 intake on the way. Thanks for any info.
E30 on 91 or 93 is a very noticeable gain over straight 91 or 93. E50 is a noticeable gain over E30.
These cars love ethanol, you’ll definitely notice a difference.
New Mexico
It does indeed take 1min to flash a tune.
It's exactly 4 button presses to do so, with the convenience of the Accessport.
Dominican Republic
Ford Explorer ST 2021
Stock 351whp
Stage 1 (W/O Intercooler)
Stage 2 (W Intercooler)
Stage 1 91 - 445whp
Stage 1 93 - 460whp
Stage 1 E50 - 505whp
Stage 2 91 - 450whp
Stage 2 93 - 464whp
Stage 2 E50 - 530whp
These numbers come from GooseTuned. Keep in mind that dyno numbers can vary depending on the environment, ethanol content in the fuel, etc.
The 91, 93, and E30 tunes really make a noticeable difference. Stock, you’re usually in the 13.8 ~ 13.5 range, but with a tune for those fuels, depending on the weather, you can comfortably run in the 12.8 ~ 11.8 range while staying conservative—many have even run lower.
E50 tunes can run from low 12s to mid-11s without issues. It all depends on the mods, weather, etc.
Slippi84
NJ
91 to 93 isn't gonna be a big difference but 93 to anything Ethanol if tuned is gonna be a def noticeable difference. Almost everyone that goes e50 says they have a hard time going back to even a 93 tune.
Charlotte
2024 Explorer ST
I'm envious of people with ethanol availability, zero around me. Would love to try it!
There is a couple tenth difference between 91 and 93. Not a big difference but it's slightly noticeable.
Agreed. Literally none in my half of the state.
Charlotte
2024 Explorer ST
From what I can find the ST is only rated up to E15 as it is not a ford "flexfuel" vehicle. Is it harmful to use something like E50?
If you’re tuned for it E50 is great. You can run up to E30 on any tune.
Stock fuel system supports up to e50 with a tune.
Marinette, WI, USA
e50 is going to be a big jump for you! It's like going from stock to tuned all over again!
George M
Painesville, OH
With the E50 tune...can I run just straight 93 if I need to? Or do I always have to run E50?
Columbus, Ohio
2x 2023 Explorer STs
The most safe answer is to never run less than you're tuned for. 93 shouldn't run 91 or 87, E50 shouldn't run E30 or 93, etc... unless you have a flex fuel tune. If you have a specific question, reach out to your tuner.
George M
Painesville, OH
Right i get that. Just wondering if zfg e50 tune sets the parameters wide enough where it allows no ethanol if you're in a dire situation
If you drive very conservatively and stay out of boost you can limp home. Consider it an emergency only option.
George M
Painesville, OH
I gotcha. Thank you.
Columbus, Ohio
Agreed. It would be emergency only.
ZFG actually has a page on their site the walk through their allowable fuels:
FUEL TYPES - Actual Page
Our tunes support one fuel type each. Fuel type options are as follows:
Auto-Octane: All Pump Gas (87-93, up to e30)
91 Octane: 91+ Octane (91-93, up to e30)
93 Octane: 93+ Octane (93 only, up to e30)
e50: 40-60% ethanol blend (no pump gas)
e85*: e85 (70-90% ethanol content)** Written for Competition Use Only, and may not be supported by the stock fuel system.
