Whistle sound when pressing on the gas pedal
vallord
Lincoln, Ontario, Canada
2020 Explorer ST with 66,000km. It started to make what I would described as a whistle sound when pressing on the gas pedal at about 60km/h and above. The pedal doesn’t need to be pressed hard.
https://youtube.com/shorts/5tOdrVk_9Ig?si=RwilrZVj2ULPI2Pk
I’ll stop by the dealer tomorrow.
Anyone has any ideas what it could be?
My guess is a vacuum leak.
vallord
vallord
Reports whistle type noise when pressing accelerator light throttle over 60kms/hr, will stop when letting off, test drive and report
• Tech Cause: Road test for concern> Noise from rear axle assy.
• Visual inspection> severe fluid leak from rear housing. suspect cracked housing
• Removed drain & fill plugs & found excessive metallic debris, indicating internal component failure.
• Requires replacement of rear axle assy.
• Tech Comments: Rear axle assy. & hardware ordered.
• Replaced rear axle assy.
• Road test after repair> O.K. - Warranty
Nice. Glad you got taken care of!
This may be happening to me at 52,000 miles! My rear axle/suspension feels bouncy and feel resistance and shaking from the back.
BillieDGoat
Hampton Roads, Va
I have a very similar whining noise. it happens when ever the accelerator is pressed starting at about 15 MPH and up...
Goes away as soon as the accelerator is released. How much did the repair run you?
