Whine / whistle when accelerator is pressed
BillieDGoat
Hampton Roads, Va
morning all,
This is my first post and I was searching the forums but no luck in finding any matching issues. Hoping someone may be able to help.
Last week my wife said she heard a whining noise when she would have her accelerator pressed. She thought it was coming from the front passenger wheel area. I road shot gun and also drove and its coming from more centerline in the car. Its hard to describe, but best way I can describe it, is a whirling whine. Almost sounds like a squeaky belt but not quite. It is only present when the accelerator is pressed while accelerating or holding speed constant, or cruise control is engaged. As soon as you release the accelerator it goes away. Present from 15 mph and up. No warning lights, no other symptoms other than the annoying whine.
Has anyone ever dealt with anything similar?
its a 2020 ST
yettihead
Lisbon, WI
2021 Ford Explorer ST - Infinite Blue Metallic
Have your rear diff checked as mined did that exact thing and once I took it in they stated there was metal shavings in the diff. I was still under warranty so it was changed out and the sound went away. You can search on here as this has been brought up.
morning all,
its a 2020 ST
Does it do it all the time? Take a video.
New Jersey
2017 Grand Cherokee
You haven’t made any changes to the intake or charge pipes recently have you? Wondering if it could be the turbos
CrystalD94
Hudson, NY
morning all,
its a 2020 ST
i have the same noise! Except now it’s gotten so much worse. I have no idea what it could be. Mine started at 30ish MPH, stopped when letting off gas pedal, and stayed constant. 6 months later it’s growling and we still can’t figure it out. It doesn’t do it when you’re first starting the car and driving down the road it seems to be when the car gets to temp then it’ll start.
CrystalD94
Hudson, NY
what did the noise start out as? Mine is growling now, it doesn’t get louder until you’ve drove down the road a little bit and the car is up to temp.
