where to jack up the rear end
Minneapolis
2021 Ford Explorer ST
I will be putting on a rear differential brace tomorrow. This will be the first time I get my '21 ExST up in the air. Pretty excited to start beefing this thing up. I have ramps to drive the front up onto but I just want to make sure it is ok to jack up the rear end under the differential. Then ofc I will use jack stands and remove the jack so I can put the ID Speed rear diff brace on. So...yeah, just making sure it's ok to jack it up there...? Thanks
Yep, just fine to do that. Could do it by the subframe too.
You don’t need the front up at all to do anything you mentioned. Just drive the rear up on ramps and add the new parts. Use a floor jack under the diff to gently move it while you add the main bolt for the brace if it doesn’t drop right in.
zekenator
Minneapolis
ok great right on, thanks people. will post pics.
