Wheel offset
Hull, GA, USA
So after my alignment I noticed that the driver side wheel sticks out further than the passenger side rear wheel. I went back and he said both sides are set to -.1 what adjustment would have pushed it out so far?
Post the sheet they should have given you with the before and after measurements
edeyoung2
Hull, GA, USA
They never gave me any sheet. The wheels were tucked before he adjusted something now I need to order 1/4 inch spacer to fix the passenger side. It only shows a bit of the sidewall outside of the fender. Where you able to push it that far when you did your alignment? Thanks
edeyoung2
Hull, GA, USA
So I took the car back to the alignment shop and the tech I've used in the past was there which was a relief. He did agree with me that the driver side sticks out farther than the passenger side. He put it back on the rack, got the camber set the same on both sides and it still protrudes. He came to the conclusion that the sub frame is off, which makes sense. So I guess I'm stuck with using a spacer on one side.
