What ethanol sensor is everyone using?
Midwest
Looking to add an ethanol sensor to my fuel system so I can get ratio readings on my P3 gauge. In talking to Unbroken he mentioned a continental series sensor but looking online there are a number of options. Looking to see what you are using (brand, model, etc) and any pros/cons.
-WickedST-
Midwest
Done… thanks.
Nick_PSUV
Vendor
Clearwater, FL
20 Explorer ST
I ran the P3 with the Continental from them also, along with FenFab lines - worked great!
-WickedST-
Midwest
Okay, I ordered the Continental Ethanol Gauge from P3 and now have everything needed for install. The Ethanol sensor install is obviously a no brainer but wanted to do a sanity check on the wiring... Is it really as easy as Red/Red, Black/Black, White/White, Blue/Blue, Brown/Brown for connecting wires? Also, what fuse location is everyone using for power and where do I connect the "Dimmer" wire?
texas
Yes, the wiring is just that simple. Be sure to mount the P3 ethanol sensor adaptor inside the vehicle (its not waterproof). I didnt use or connect the dimmer wire.
-WickedST-
Midwest
Thanks Loaded!
Which fuse did you tap in to for the power?
texas
I used the 4th fuse in the middle row.
-WickedST-
Midwest
Thanks!
-WickedST-
Midwest
Okay… more questions. I assume I am really overthinking this install so here is what is hanging me up. According to the P3 site we only need the OBD2 port for the gauge to work but I am adding the ethanol sensor. Do the power and ground for the sensor and ESVA need to go to the same power/ground locations or can you separate them? Also, where the heck are you all entering the vehicle behind the fuse box in the engine compartment?
-WickedST-
Midwest
Never mind…. Wiring everything together and made my own wire entrance.
