What Are These?
While trying to find how water is getting into the passenger side floorboard, I found these dangling behind the battery. What are they for?
FL
2024 Explorer ST
From the size of the wires going to it, my guess is a battery warmer?
Heated windshield connections.
Oh, that’s great! Either the windshield was replaced at some point, my mechanic pulled them off when he took the cowl off to do the spark plugs or the stereo installer pulled them off when he replaced the battery! In any case, it’s my issue now! I just have to figure out if I even have a heated windshield and how to connect them. Thank you!
KCM
Nebraska
My windshield had been replaced before I got, and luckily they installed the heated windshield. To see if it is heated, take a flashlight and shine it along the bottom edge of the windshield around the windshield wiper in the dark area. If heated, you will be able to see the heater grids. I'm pretty sure those tabs are supposed to be soldered to the windshield, so may not be a do-it-yourself job.
Yeah, now that I know what they are, I was able to research them. The windshield was definitely replaced. These come with a new windshield. Whoever replaced it didn’t replace it with a heated windshield. There are no elements in it. I called my local Safe-Lite and supposedly the heated windshields were prone to cracking so they don’t use them. I just need to go in with Forscan and disable the feature.
