Vibration after downpipe install
Hull, GA, USA
Installed cvfab downpipes and now the driver side midpipe is rattling and shaking at 1500 rpm. Would that issue cause the vibration felt inside the car? I also hear the rear heat shields vibrate at wot. The borla s-type mufflers are not touching any bolts on the heat shields. Is it time to scrap the system and get thermal or fix the midpipe?
Combatvet
Are you sure that there isn't an exhaust leak at the DP's? That's the problem I had with the CVFAB DP's they sent me, had to have a shop fix that issue.
edeyoung2
Hull, GA, USA
Did the leak crate a vibration?
Combatvet
Yes, and it sounded horrible. Take it to exhaust shop that specializes in exhaust work.
edeyoung2
Hull, GA, USA
What was the fix?
