Transmission Flush
Downers Grove, Illinois
Hello, new to this forum & need some advice for my 2020 ST. Almost at 70K miles, is a flush needed? Occasionally on highway when accelerating feels like hitting rev limiter and RPM's not at 5,000.
Not a fan of flush on any vehicle. In your case I would suggest a double drain and fill. Drop pan, reinstall,fill with fluid. Drive around for 15 minutes then do it again. Fresh fluid should help but if it’s slipping bad it won’t fix it.
I would never do a transmission flush. Best way to do it is to do a full pan drop and filter change. You are due for it I would say.
K
Thank you!
K
Thank you!
