Tire wear on the inside of my front tires
Woodstock, GA, USA
Tires are worn to the belts on the inside of my front tires only. I have stock 21" wheels and Steeda lowering springs. Do I have a camber issue?
Could be negative camber or toe out. Did you have the alignment checked after the springs were installed?
Yah you'll need an alignment.
FORZDA3
Gloucester, VA, USA
Almost certainly it’s a toe-out problem. You must run a lot of negative camber to actually wear the tire excessively. About -1deg front camber is perfect for a street car. Zero to 1/8” total toe-in is good too. Alignment shops just get it in the “green” which has a huge tolerance. Specify exactly what you want so they have the correct target.
L
Woodstock, GA, USA
I'm afraid the last shop that aligned it when I put the new tires on screwed it up. These tires only have 12k miles on them so I'm pretty pissed to have to go out and spend another $1700 on tires so quickly.
You need to take it back to that shop then and ask for them to realign and pay for the new tires.
