Thoughts on this mod?
Miami, FL, USA
2022 Explorer st
Hi all,
Recently came across this vid on youtube, I will be trying it this week to see what my results are.
Posting the vid incase anyone else wants to try.
This is not my video, not trying to claim rights to it, just posting to share info
San Diego
So wait, is there a part 2? lol cuz he states what the “problem” is, but doesn’t mention a solution. Would a silicone hose with a hose clamp be better? Update: ahhh I read the comments in YouTube. turns out he capped both ends off. Not sure if that’d be good or bad.
S
Miami, FL, USA
2022 Explorer st
He states its causing a boost leak, not sure where exactly this hose attaches to, but ill take a look
It goes from the IC to the driver side tube to the turbo. It is an odd hose…now that I think about it.
S
Miami, FL, USA
2022 Explorer st
I suspect there's a check valve, there's no way ford would have designed a massive boost leak
I asked on our FB group and Adam posted this:
San Diego
Interesting. So I’m guessing capping it completely off would be bad? Would going with a silicone hose with hose clamps be beneficial in place of that?
S
Miami, FL, USA
2022 Explorer st
i think the original owner of the video was implying that the tube itself, was a boost leak since it goes from the high pressure side (intercooler) and connects to the low pressure side (intake tube).
Yes, capping it off would be bad. Another reason to be very careful about shade-tree mechanics posting info online! I mean it's not like Ford has actual engineers doing this kind of stuff- you should immediately jump to the conclusion that they purposely built in a boost-leak! I guess because they had no other way of controlling boost? Quick, post a video documenting your ignorance! LOL
I'm waiting for the video showing Ford purposely is limiting horsepower since they bolted the turbos to the head- gasp, no headers!
San Diego
LOL. I don’t see any follow up videos from the guy. Hopefully he didn’t ruin his vehicle. :unsure: He ran a 12.7 @ the track though. But that vid was posted a month before the boost leak one.
San Diego
I asked him, on YouTube, if there were any updates on this or if there have been any negative side affects so far. He’s claiming a gain of about .5psi and says there haven’t been any negative side affects so far. So….I guess we’ll have to wait and see. I can check in with him again in a week and see how things are going.
After a bit of research, that "pipe" is part of the EVAP system which prevents hydrocarbon emissions from entering the atmosphere by storing fuel vapors and routing the vapors to the engine to be consumed during normal engine operation. I did not find any info that it was also used for crankcase ventilation as suggested by post #6 but it's not out of the question.
Pertinent to the ST:
  • On turbocharged engines, an EVAP ejector is used to create a vacuum in the purge line during boost conditions. When in boost conditions a percentage of the boost pressure is applied to the EVAP ejector to create a vacuum. This vacuum draws purge vapors through the EVAP ejector into the intake air system upstream of the turbocharger.
So, this is part of the EVAP system so it will function under boost conditions when there isn't vacuum to route directly to the intake manifold.
Don't play with it.
San Diego
Don't play with it.
Ahh ok, good to know, he said he hasn’t gotten any CELs yet, but I guess we’ll see.
S
Miami, FL, USA
2022 Explorer st
Thread Starter #15
I'm gonna see about pressurizing my intercooler and pipes this weekend to check if it indeed leaks under boost conditions
That hose isn’t a leak in and of itself and that’s not what the guy meant in the video. He thought it was leaking boost pressure from the intercooler back into the turbo inlet. He is incorrect in that assumption.
Technically, it is a "boost leak", but it's minuscule. I doubt very highly it's 0.5 psi (how it that being measured, and what does it have to do with actual mass airflow?) It's there on purpose to supply a way to purge cannister vapors (and possibly crankcase ventilation) during boost conditions. It is not hurting performance in any way as the ECU can easily command more boost to make up for it. This is not a "mod", it's superstition. If you want to spin your wheels playing with things you know nothing about you'll be rewarded eventually with some strange EVAP or PCV related codes.
The way I understand it…and I could have read it wrong…is that it doesn’t “leak” boost but pulls a vacuum instead. I just glanced at what I was reading though.
Here’s the link:
http://www.hendersons.co.uk/wms/venturi_principle.html#:~:text=Venturi Principle|How do venturis work&text=A venturi creates a constriction,a consequential drop in pressure.
You're absolutely right. Using boost pressure through a smaller orifice (jet, nozzle, ejector) causes the velocity to increase. The increase in velocity produces a decrease in pressure. When used with a properly sized orifice this will make a vacuum, the same way carburetors and paint sprayers work. During boost, there is no vacuum in the intake manifold, so because we don't wish to vent hydrocarbons to the air, it looks like Ford is using this method to direct them into the intake of the turbo so they can be burnt. The info in post #13 came directly from the service manual. It's a bit vague, but they may be because they have used various mechanisms and don't wish to rewrite the manuals constantly.
But yes, some of that "boost" does "leak" back to the compressor inlet. As I said before, it won't have any effect on performance.
San Diego
Ahhh…all good info guys! Thx! So it basically is it acting like a recirculating component? Similar to what a recirculating bov would do?
