Thermal cat back... Weld or Clamp?
How many of you only clamped your Thermal cat back with no issues? Curious if I should weld certain areas of it during install or if the clamps have been reliable and no need to weld?
Southern New Jersey
I have been clamped for 2.5 Years. Only issue I had when I did my downpipes I had to use a little permatex to seal the Midpipe connection to the downpipes with the clamps
I clamped mine and no issues.
As a note, pay a lot of attention to the tips. They require significant torque and seem to take forever to fully hold. I did this and the next day could still twist by hand so hit them again.
Also , don't forget to flip the muffler hangers and knock the dog ear off that clips into frame. It is not needed as the bolt does the job and likely something from the factory/assembly process.
SugarMouth
Sorry not following here, the muffler hangers need to be swapped or?
The factory hanger mounts have a rubber side and plastic side of the grommet holding the hanger itself. The hanger of the thermal will eventually rub on the plastic side causing NVH and knocking sound. Some (including me), reverse the hanger mounts leaving the rubber side meeting hanger itself.
SugarMouth
Got it, thanks!
I haven’t heard of anyone welding it all together, clamping seems to be just fine.
561
Just bought the Thermal 3.0 for my 25 waiting on it. Had it on my 2022 never had an issue with the clamps other than stripping a nut on one my fault entirely (careful on the torque) but they replaced it ASAP for zero $$$
SugarMouth
So far so good on mine being clamped. I checked all the clamps after its first cool down and they needed nearly nothing. After a couple weeks rechecked while cold and zero adjustment needed. Fingers crossed.
