Thermal 2.5 vs Borla Type S
which echaust are you currently running?
  • Total voters
  • Poll closed .
Haven't experienced the S-Type but the ATAK is loud and you can expect some drone at cruising speeds.
Sacramento, CA
2022 ST
I like the Thermal also, but is the sound signature much different between the 2.5 and 3? And (being new) I see a lot of clamps on the Therma. Isn't that an issue (or at least a potential issue)?
Thank you,
there has been a few issues with the clamps on the Thermal. some have had to change the clamps to something different due to the clamps failing to stay tight. I actually am having an issue with my rear muffler sagging due to the clamps not holding tight enough. i might put a quick tack on it just to keep it from moving as it has moved several times since the install.
Armsen
Houston
Thermal 2.5 has no highway drone. I currently have it installed. I have had Borla S Type and Magnaflow in the early days on my 2020 Explorer ST. Magnaflow was the only one with a pronounced highway drone.
Would you say the Borla or Thermal was louder? Looking for minimal mid-range fartcanning. Coming from an MBRP axle back that sounds….civicy
