Steeda powdercoating question
JTwizzST
Massachusetts
Hey Guys!!
New to Explorers and this forum but not new to cars.. Been reading a bunch about different mods and I have found a few posts regarding Steeda's powder coating not being very friendly to the northern-tiered states for purposes of corrosion. Would it be worthwhile to get one and have it re-coated or perhaps go with the PIU version? I don't think I am going to need much adjustability but want the thicker bar.
Thanks!!
JT
Well, there is also the aFe sway bar too--although time will tell how durable the finish on that is.
J
JTwizzST
Massachusetts
Gotcha.. I am leaning towards the PIU, mostly for that reason, but the roads around here are more like "urban off-roading" than typical roads.. I am about 30 miles outside of Boston and the road salt is absolutely destructive to cars and finishes. Do you know what the size of the aFe is?? Is there any merit to aftermarket links? Does anyone even make aftermarket links?
Thanks again!!
Welcome to the forum.
J
JTwizzST
Massachusetts
Thanks!! I suppose I would have to have the springs done. Now, I need to see if I can get my ride looked at. Pulling out of my spot at work, "Traction Control" light came on.. I straightened out and started driving when I suddenly got 6 or 7 alerts, Hill Descent Assist, Lane Keep Asisist, ABS, Pre-Collision Assist, etc... Sounds like the TSB 20-2071 or something like that whereas one of the speed sensors needs to be changed.. Hopefully that's it.. I haven't even put 300 miles on it..
I’m considering pulling my rear springs and having them powedercoated. I love Steedas products but in this day and age there is no excuse for rusting springs in 18 months imo!
The midwest
Any suspension component that flexes and twists will crack away the powder coating and rust. My Steeda bar was wasted after two years, but my OE springs and front sway bar look perfect after four years and 40,000 miles in MI & OH. The PIU rear bar will probably hold up just as well. Ford used to call it E-Coating many years back, but I’m not sure what it’s called now.
Throw on the PIU part and be done. The factory springs (ST/PIU) are actually quite good, and if you tow anything, they are that much better.
