Softening the ride on an ST?
Carlisle, PA, USA
Hi all, - I know I should probably appreciate the sporty tight ride feel of my 2020 ST but it's such tight suspension that it's not pleasant for just driving around town - especially rolling over bad pavement. I knew at purchase it would have a tighter feel, but the other pluses of the ST far out-weighed that as a concern.
But now I'd like to research what my options might be for adjusting and/or upgrading the suspension so I can soften the ride. Is there anything I can do with the existing vehicle to soften the ride? I assume no.
For upgrades, I've heard of air ride suspensions, and that could have adjustability but sounds expensive and custom. Apparently the Ford Raptors have dampening adjustability of the fly but I can see how that makes more sense on a Raptor than an ST.
I read the ST coils are 8% stiffer than the coils on the Platinum. Replacement of coils could be a lower cost option than an air ride upgrade but I assume no adjustability once installed, and probably still expensive for parts and install.
FV Suspensions just confirmed with me by email they don't have any kits that could help soften the ride. They do hear this as a common issue with the ST being quite stiff from the OEM.
Has anyone looked into this issue and has any thoughts or experience to share?
Thanks, -
First get the Platinum struts/shocks and springs. Then, downsize to smaller diameter and lighter wheels. And get appropriately sized tires with a fatter sidewall.
EDWYER
Black 2020 ST
Going to the OEM 20's and Michelin's will improve things.
bosephbarking
GA
This suspension is far from stiff. Is it stiffer than most SUVs sure, but it's not bone jarring by any means.... (Try a Honda CRV for reference of what stiff is). As others have pointed out the best option is dropping rim size and getting higher profile tires.
Charlotte
2021 Ford Explorer ST
My dad’s CRV is way smoother on pavement and around town than my ST, what are you smokin. And that was before I upgraded the entire suspension. The CRV is obviously a small crossover tuned for comfort whereas the ST is simply not. I had to drop rim size and increase tire height to make it manageable where I live.
Ontario, Canada
Hi, I picked up a set of 2020 xlt rims and tires (255/65R18) and used them for a number of years (tires are now worn out). I recently switched back to the stock 20" wheels and my wife and I definitely noticed a stiffer ride. I would suggest the easiest way to have the best of both worlds is to get an 18" set of wheels for comfort and keep the 20"/21" for sporty trips. Good luck.
Mobile, Alabama
2025 Explorer ST 4WD
Yeah, 18s are nice, but I hate the look—too much tire.
Massachusetts
2023 ST
I agree with the other poster's comment. I have my '23 ST and my wife's '24 CRV, and I do think my ST rides much nicer than the CRV
Charlotte
I guess the new CRVs are a harsher ride than the ‘17s… or your ‘23 ST is built different than my ‘21. My ‘21 had very little dampening before I added any aftermarket parts or upgrades to it. Or maybe your wife’s CRV has larger wheels on it than the one I’ve driven, which gives it less cushion. But in the end.. whatever.
Philadelphia
21’ ST and I have to commute over cobblestone daily. It’s stiffer than my old 4Runner. Could be worst of course, but even on smaller wheels and giant AT tires, it’s still noticeable. If I there were adaptive suspension options that softened without lowering it I would cop it in a heartbeat.
2025 ST
Agree and make sure tire pressure is 35 cold.
EDWYER
Black 2020 ST
Do you have the 20's or 21's?
OK ST
Edmond, OK, USA
The problem with the ST is the shocks, not the springs. I've been waiting for someone to come out with a replacements shock that has better compression damping. Keep thinking that Bilstein will eventually come out with a set of struts and shocks.
