Rear A/C vents
Jshaffer3819
Kaiserslautern, Germany
Anyone have an issue with the second row overhead A/C vents not blowing air? My right rear passenger one isn’t working but the left one is. Probably disconnected inside.
This was reported by another member a while back and it was an assembly issue. Those crackheads in Chicago!
Jshaffer3819
Jshaffer3819
Oh boy. I guess I’ll have to make a service appointment.
Honolulu, HI, USA
See if your rear a/c is on when you check on screen. Hit the rear a/c button on your dash and it will come up on the touch pad. The fan and temperature bars will show if it is on. Mine some times is not on when I start out and has to be set onscreen.
Detroit, MI
2020 explorer
Found this because I am having the same issue. Have had it in for service multiple times and they can't track down the issue. Any known way to solve it?
Desert South West
Is air blowing out of the rear bottom vents when its supposed to be blowing out of the top vents? If so it could be your Rear Air Distribution Door Actuator.
Bumping this because I have the same issue.
FB post was asking about this. Claimed pass side 2nd row vent was working, on max AC, but nothing on the driver's side 2nd row. Lots of folks claim to have the same issue and when brought in for service, the dealer told them "normal".
So i hop in my '23 and low and behold, same thing. Very little to nothing out of the passenger side on max AC.
Is this really "normal" or should I make an appt?
