Power source for dashcam?
Tom in MF
Menomonee Falls, WI
I want to install a dashcam high up on the windshield to the right of the rear view mirror. Anyone know of a good ignition switched power source up I can tap into? Short of that, any tips for running the power cord down to the center console?
T
Tom in MF
Menomonee Falls, WI
Farmers Branch, TX
Do you want it running all the time, including parking mode, or are you just interested in running it while the vehicle is driving? The later is easiest to power with an adapter connected to the powered mirror.
Chairborne Ranger
I've used the Dongar adapters that run off the mirror power and they are easy to install and work well. The downside is they only provide power when the vehicle is running so if you need fulltime juice they aren't your answer.
T
Tom in MF
Menomonee Falls, WI
That would meet my needs since it's usually garage kept and I'm always parking waaaaay out on the end of the parking lot.
Thanks for the Dongar recommendation - that's exactly the solution I was hoping for. Watched their video and seems simple enough.
Thanks guys!
