Police interceptor headlights in Civilian ST
Ghost117
Hudson, OH, USA
Just a short background. The interceptor headlights use the amber turn signals as DRL instead of the long white strip and I just love the look. I've tried everything in forscan to make them work in the way because there are options but have not succeeded.
Just out of curiosity. Does anyone know if you can plug and play interceptor headlights into the civilian model? I'm not sure if it would be simple, or programmed differently and wasn't sure if anyone has tried.
If anyone has an answer, please post in here.
Looks so much more aggressive.
Minneapolis, MN, USA
Agree with you 100% that the amber as DRL looks so much better! Saw you no the other thread about tweaking this in Forscan but that delay makes it kind of annoying. Kept mine on for now though. If you find a solution please make sure to update this post!
Every time I see Kia's with amber DRL's and my old Lincoln MKZ (some had amber, possibly Canadian models) I cringe. I have always preferred the bright white DRL's. To each their own!
Michael Grasso
Indianapolis, IN, USA
2022 Explorer ST, 2021 Bronco Badlands
I like my ST the way it is, when I want the interceptor look I drive my other car. Lolol
bumping this post, has anyone tried this yet? if so where’d you get the interceptor headlights?
New Hampshire
(2) 2021 Explorer ST (White & Carbonized Grey)
It looks like there are several variations of the piu headlamp (level 2 - level 7?) and I can't figure out what the difference is between them. They're also like $1100 each, so I won't be the guinea pig lol.
College Park, Maryland
I'm following several on ebay but I'm only aware of low, mid and high levels (based on the flasher bulb sockets or LEDs in the unit). My concern I think is shared with everyone on this thread: is the internal module and plug compatible with an ST? If so, should be plug n play.
California
2022 Ford Explorer XLT
So I’ve just become the guinea pig for you guys.
i found a very nice set of interceptor headlights on marketplace for $650 so i picked them up and just today I plugged them in to check compatibility. I found out they work perfectly! It seems the light setting is fully in the headlight module and isn’t related to the car computer at all so it’s plug and play all day.
I just have a quick mockup picture here since I need to take the time to pull off the bumper to install them. View attachment IMG_5530.jpeg
Moss,Tennessee
2021 Ford Explorer ST
What Level are they and do they have part numbers on them?
