Painted Red H&R Lowering Springs!
Derry, NH, USA
Finally got my lowering springs from Whoosh! Took almost 3 weeks.
Painted them red today!
Painted on a base coat primer, then 2 coats of red, then 2 coats of protective gloss.
Came out the BOMB!
Cost was $28.99
zdubyadubya
let us know how they hold up. (y) several guys have powder-coated theirs. curious how paint does because its a significantly cheaper route. i have found rust-oleum to be surprisingly durable!
smithero
Derry, NH, USA
Ill keep you posted. They are being installed on Monday.
LokiWolf
Henrico, VA
Solid paint won’t work.
It Drys in a solid sheet. As the spring compress and decompress it will flake off. Regular paint will not work for anything that changes dimensions like a spring.
I hope you prove me wrong...because like was said above it is cheaper.
Powder coating works because of how it bonds.
A rubberized coating might work...
So did the paint stick?
