Obnoxious Rattle in Driver Door
SilverST
Chattanooga, TN, USA
Hey, y'all. New to the forum here, glad it exists!
So we got our ST about 3 weeks ago and it has had the most persistent rattle in the driver door (among other places, but not so bad there) when listening to music. Dealership looked into it and tried a few things. It worked for 2 days and is back.
Any idea what it could be?
Toronto, ON, Canada
Mine does it too. One of the only things that bothers me about the truck. I find 2 things happen... I either have to push down the interior door handle(that opens the door) or push the lock pin itself. I doubt the dealer will be able to fix it it’s probably something the car audio guys have more experience with
SilverST
So far in my experience, I can press anywhere (my default is just putting a little pressure with my knee onto the panel, it's not fool-proof unfortunately.) It lessens when the door is locked. I'm gonna get a panel tool and pull the panel and just deaden the whole lot of it.
I had ford look at it while they were fixing a messed up D-pillar clip. They did trial and error for 4 hours and ended up putting a strip of felt along the door, to no avail.
SilverST
So I just took the panel off and lo-and-behold, it was the lock/unlock cables. They were clearly not secured and are a thick braided metal wrapped in thin foam. Secured with zip ties and a layer of Stinger Roadkill, we are good to go now!
All ya need is a 7mm and 10mm socket and, if you're afraid to just go tugging on panels, a panel removal tool.
