New to me 2023 st line
Mopitcher
FL
2023 St Line
Hi all. Former expedition owner and now have a new to me 2023 st line. Loving the ride. Curious about upgrades? I got the front windows tinted and got the in channel rain/wind guards (really nice to have here in south Florida). What else have some of you done? Also looking for a quick fix to get rid of that auto engine stop. Hate that. I've seen a few ways but im not tech savy and a bit intimidated by that. Any ideas? Thanks in advance.
Look at the Auto Start Stop Eliminator. I'm sure there are other brands that do the same job but since I have first-hand experience with this one, I'll recommend it. These don't permanently eliminate the function but will remain in the off position if that's where you had it when the vehicle was shut down, push the button and you're back to factory.
These truly aren't difficult to install, probably 30 minutes, they are plug and play. You simply need to remove the steering column cover at the bottom of the steering wheel, just a few screws, unplug the harness, install the device between connections and reinstall cover.
I'm not sure on this with the 2.3 L engine or even if the line has a Sport Mode (pretty sure it does) but if it does, driving in Sport removes that function while in that mode.
https://www.autostopeliminator.com/...tostop-eliminator?_pos=2&_fid=aee2e62d7&_ss=c
Mopitcher
Mopitcher
FL
2023 St Line
Get an Auto Start Stop Eliminator. I'm sure there are other brands that do the same job but since I have first-hand experience with this one, I'll recommend it. These don't permanently eliminate the function but will remain in the off position if that's where you had it when the vehicle was shut down, push the button and your back to factory.
These truly aren't difficult to install, probably 30 minutes, they are plug and play. You simply need to remove the steering column cover at the bottom of the steering wheel, just a few screws, unplug the harness, install this between connections and reinstall cover.
I'm not sure on this with the 2.3 L engine or even if the line has a Sport Mode (pretty sure it does) but if it does, driving in the Sport removes that function while in that mode.
https://www.autostopeliminator.com/...tostop-eliminator?_pos=1&_fid=a669f480e&_ss=c
Mopitcher
Mopitcher
FL
2023 St Line
Much appreciated. Ty
Like Gearhead said, auto start stop eliminator device will easily fix that. Welcome to the forum!
