new recall?
G
gafool25
Guest
Got this in the mail its scheduled but im one of the first to inquire about it per the dealership im using? its called customer satisfaction program? Turbo hose routing inspection and repair?
now this my just be the dealership but says the way ford wants it is it takes a few days to do this? which i say is bull? im gonna call another dealership and see what the turn around time is
St. Louis
Can you explain this situation more with some details? I have no idea what is going on with the data you provided.
G
gafool25
Guest
? what "data" do you want? i got as notice in the mail. From Ford. it is about Turbo hose routing inspection and repair. theres your "Data"
You could either attach a copy of the letter or at a minimum post the customer satisfaction number on it. No reason to get huffy about it.
PAZZI
Las Vegas
2023 Explorer ST- Agate Black
Interesting. When we picked up our 2023 ST on 4/21/23 (built on 4/1/2023) it had an oil leak. The diagnosis was a drivers side turbo oil feed line which was repaired under warranty. It took almost a month from drop off at dealership to post repair pickup.
Jeppo
Davidson County, NC
It doesn't look like it. The article states it is for Explorers with the 2.3L motor.
In his first post, the OP mentioned he bought a 2.3.
PAZZI
Las Vegas
I suspect it's more widespread than than the 2.3, based on personal experience. Time will tell.
In that same post he also stated he bought an ST. So I assumed he is posting about the ST as it's in this forum.
I could be wrong but who knows?
Atlanta, GA, USA
It looks like both of you are correct on what he has. His post shows an XLT with the 2.3 and an ST. Possible OP didn't verify the VIN for the letter and it could be for his 2.3
Might be an ST Line.
G
gafool25
Guest
Thread Starter #13
ok well apparnetly no one has gotten the letter about the turbo hose routing inspection and repair so its all good.
St. Louis
Coherent sentence structure to start.
Bowie, MD, USA
Maybe we can help more if you tell us what the CSP reference number is.
